I am selling a set of JIC coil overs to suit an R34 GTT coupe.
Aluminium strut tops with spherical bearings
485lbs/inch or 8.7kg/mm springs (from memory!)
The springs are stiff but it is useable on the road. My car was unbelievable on the track with these coil overs - totally transformed the handling of the vehicle.
40mm (huge!) shock absorbers
Excellent condition - no leaks etc.
Price $900
I can be contacted on 0409 903 669 also
Thanks,
Toby.
https://www.sau.com.au/forums/topic/262992-r34-gtt-jic-coil-overs/
Price $900
Thanks,
Toby.
I just got an email from JIC support stating these coil overs also suit an R33 GTR
Does this sound correct?
Price $900
Thanks,
Toby.
PRICE DROP TO $800!!
are these height adjustable?? to be able to lower the car?
Just to help out with a quick answer ( hope you don't mind Toby ).
Yes, they are height adjustable. In the first pic you can see the remaining thread under the spring seat and lock nut if you want to go low. If I did'nt already have coilovers I would have grabbed these already. ;)
Yes, they are height adjustable. In the first pic you can see the remaining thread under the spring seat and lock nut if you want to go low. If I did'nt already have coilovers I would have grabbed these already. :blink:
Thanks for helping out with the answer mate - don't mind at all!!
Now someone buy them!!!!!!!!!!!!
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
