So well I broke the little cheap plastic thing when I was changing my light for LED on my cluster. So I ordered my cable from nissan. I searched a lot. and I learn that the cable is connected to the gearbox and pass throught the firewall.
But euh.. does some have picture of where exactly it goes? and how do you disconnect it? Will I have to change the fluid after?
Thanks :D
I assume this in an R32 ?
There are three bolts to undo in the engine bay, near the steering column. Undo these, pull cable to the left in the cabin, and it will come out from its slot. Pull from the engine bay, making sure now and then it's not getting caught on something. Crawl under car, unclip cable from brackets, unscrew shield from gearbox..
Fit new cable reverse of this.
No you will not have to change your gearbox oil.
So I tried to change it today. WASTED 3 HOURS OF MY TIMESicon_ChairShot.gif.
How the heck do you UNBOLT THOSE 3 BOLTS?? Is there a special tools? I can't do it with a tiny screwdriver because I don't have enought force. With a long screwdriver it just wont fit.
And with a ratchet, I don't have enought space to ''wind up''
My car is a BNR32
Edited by cobrAA
You will need a socket, or spanner (I think it's a 10mm) and nimble hands :) but no special tools required. There isn't much room I agree to move around, maybe less so on a GTR.
If you jack up the car, it may be easier to do it from underneath.
Yeah 10mm bolts. 3 of em. ratched with extensions is all you need. The whole plate comes off the firewall. I did have my dash out as I think there is a clip just before it goes into the back of the cluster.
It's a simple job.
Okay . 4 hours later. Job is still not done. So I'm down to a 6 hours spent and still not done...
How do you insert the gearbox cable end STRAIGHT??? I spent the last hour trying to bolt it but it will always go too much to the right, too low, too high. It just wont ****in go straight and fit so I can bolt it.
I did insert the metal piece in the hole of the gear box but I just can't bolt the bolt on the gearbox because it is misaligned..
Please Help serioulsy. I'm really about to sell my gtr because of that freakin stupid 70$ mods.
umm i thought the cable that fits into the gearbox end has a notch and fits only 1 way.. bugger.. maybe try with the old cable on the gearbox to see how it fitted
For sure it is one way, but since the cable is so ''strech'' it wont hold in place. so it will make my bolt ''offset'' so i can't screw it forward.And the force is so big that I can't hold the cable at the ''right'' place with one hand and screw with the other.
Hope you understand what I mean?
Edited by cobrAA
have u already plugged in the other end to the cluster?? from memory, my cable had a nice loop before coming into the gearbox, certainly wasnt strained like yours??
dont know if gts-t cables are any shorter, maybe wrong cable supplied by nissan.. gts-t ones have few teeths to the gtr so wont work on gtr but not sure if length is different
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
