The fact that I got 411rwhp isn't of much interest. The fact that I did it on stock internals, stock cams and stock injectors is.
I had been led to believe by a number of people that without cams that I wouldn't be able to flow enough air to make that sort of power, and that I would have run out of injectors long ago. So I thought I would share this with you incase you decided you had to buy them to make decent power.
I'm running a GT30 (500hp) at 17psi. We currently only have 9deg of timing so that the stock pistons don't blow, so even with the current setup and forgies we have a heap more power available.
Hope this of interest to those of us who own whales:D
https://www.sau.com.au/forums/topic/26304-411rwhp-from-stock-internals/
  • Replies 335
I'm a bit confused from the above quote where you say "so even with the current setup and forgies we have a heap more power"
Does this mean you've got forgies or are planning to add them?
Buster, Meaning that keeping the boost at 17psi and just by increasing the timing we can get another 20+ hp easily. I don't have forgies yet, but as soon as I can afford them they'll be going in:D
2rismo, I'm sure the injectors are standard 370cc, I'm using a Malpassi fuel reg, with about 40psi of fuel pressure.
Injector duty is on about 80%, so I'm hoping to keep the stock injectors a bit longer.
Hi GTS-t VSPEC, when you say "I'm using a Malpassi fuel reg, with about 40psi of fuel pressure". Is that 40 psi above boost? ie 40 + 17 = 57 psi. Or is it 40 psi total? ie 17 + 23 = 40 psi.
Hmmm 40 psi is only a little above standard, hmmmm.
This is prety simple maths here, 370 cc's per injector, 6 X injectors, 1 firing per 2 crank revolutions, 12 to 1 A/F ratio, 2.5 litres engine capacity at 1.15 bar (17 psi) at 90% engine efficiency. You end up at 370 bhp (+ or - 5%) at 80% duration. The 20% is for acceleration enrichment, ambient conditions, cold run etc
So 411 + (say for losses) 70 = 481 bhp. That's 130% duration.
In order to get the sort of flow we would have to increase the fuel pressure to 60 psi above boost. In your case that would be 77 psi which is 4 psi above the Bosch Motorsport fuel pump maximum. There are other pumps rated higher of course, but hen you start to run into other complications, hoses, clamps, voltage drop etc.
I'm perplexed??????????????
Hi Buster, you asked "do you use a fuel reg on all your cars or is it only needed if the injectors are maxing out?"
Adjustable fuel pressure regulators are a bit of a "band aid" really. They are OK to fix a slight problem when budget is a concern (as it generally is). Bottom line, I prefer to get the right size injectors in the first place.
Hope that helps
Hi R32-GTS, it has been my experience that the laws of physics always apply. Whenever I search enough, I can find an answer, and restore my faith in the laws. There is obviously a reason for it, we just need to find it.
This is pretty simple;
either the injectors flow more than 370 cc's
or
the fuel pressure is more than 40 psi above boost
or
the calorific value of the fuel is higher
or
well, let's leave that one............
Hi guys, there are a couple of other clues here....
Simplistically, boost is resistance to air flow. You run higher boost because the engine won't allow the air to flow into and out of the combustion chamber. The GT30 at 1.15 bar is a little under its most efficient ie; a bit below the sweetspot on its compressor map. About 1.3 to 1.5 bar is pretty much right in the middle to achieve its 500 bhp rating. Now 411 rwhp (480'ish bhp) is pretty close to 500.
My experience has been that a standard flowing RB25DET (standard cams, ports, inlet manifold etc) with a "perfect" intercooler and exhaust manifold, needs 1.4 to 1.5 bar to overcome these standard restrictions to air flow to make 450 bhp. Reducing the restriction (longer duration, higher lift cams and port work being the main ones) you can get 450 bhp at lower boost levels (1.1 to 1.3 bar).
To make close to 500 bhp, I would have to run 1.7 to 1.9 bar, which is past the max efficiency point of the GT30, but achievable.
So I'm perplexed over this as well...............
Sydneykid, Glad I've got you stumped on this one, I was shocked aswell. I know I only put BP 98 in the tank, mixed in the correct proportions with Octane booster. The injectors have been in there since I bought the car, and the car was 100% stock when I bought it, so I'm confident that there are stock. I would agree that sizing the injetors to meet the application, but seeing as we're not even at 90% duty cycle then the stock injectors are working great.
I'm using the stock fuel pump as a lift to a 3litre surge tank, then a 910 Bosch pump into the Malpassi.
I have the Greddy plenum, 100mm throttle body, custom exhaust manifold, R34GTR intercooler, if that helps with any of your calculations;)
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
