  • Replies 335
Hi guys, it would be nice if just adding a plenum dramatically improved the efficiency of the engine. But it is well proven that RB's are over 90% standard, some measurements put them at 92%. There is no way any plenum can make a 370 cc injector flow 130% of its rated capacity.
It might improve the airflow, but that's not petrol. Remember there is only 8 to 10% efficiency left to get to 100% and there is no engine around that is 100% efficient. A Formula 1 engine is 97.2%, from memory.
So I'm still perplexed.............
Sorry Steve "about 11.5 to 1" isn't good enough for calculations. It also just makes it more difficult to understand, 370 bhp is based on 12 to 1. With 11.5 being 4% richer, that makes the max flow capacity 355 bhp.
mmmmmmmmmmmmm?
I think the answer was brought out when VSPEC said that other cars at his dyno are pulling 350horses with standard injectors. I think once again people are throwing blind faith at dynos being accurate. Not trying to detract from your car in anyway dude but its seriously baffling, but i think you'll find if more than 1 car with standard injectors are making magic pixie land kinda power on the same dyno then the dyno is not on par with other dynos.
my 2 cents sorry again if i seem to be raining on your results man.
Hi Steve, as I said before I am always suspicious when I see things that don't agree with the common laws of physics. Might I respectfully suggest that I see a lot of horsepower numbers out of WA that don't seem to be supported with track results. One example is the HPI Street Drag Challenge, out of the 50 cars listed (top 10 of each class) there is only 1 WA car on the list.
Maybe there are a whole pile of other reasons, but I see a huge number of very high powered WA cars in every magazine I pick up. But I don't see the track results that support it. Maybe I am not looking in the right places, it is just what I personally have observed.
Maybe it's just my sceptical nature.
Well, I can name a couple of guys here in SA off the top of my head, one making just under 350rwhp another over 350rwhp - that was on the morpowa dyno, tuned by martin donnon (in one case) - and he doesnt fudge figures to cater to anyones ego.
The problem I beleive is often people just dont want to believe that something is possible if it flies in the face of everything they have thought to be true.
As for dyno figures in WA, there is a dynojet dyno in Myaree (suburb of perth) that reads incredibly high - I had a mate in WA that had 298rwhp with a turbo back and 12psi of boost on an R33, alot of people who just want a figure to brag about use it, its one that is favoured I believe by X-speed, so you are quite right to think along those lines.
The dyno that Paul used isnt that dyno - its a dyno dynamics dyno. I have seen a handful of kw difference between dyno dynamics dynos, but not as much as people are suggesting.
I dont blame you for being sceptical, it is pretty bloody incredible - but maybe there is something new for people to learn here.
I'm making 339hp @ wheels (on 1bar) currently, but at the flow limits of the stock exhaust manifold, as we had to pull a reasonable amount of timing out of the top end to stop it from pinging. I also think its getting fairly hot in there now too, so I need to wrap my dump pipe and get a ceramic coated exhaust manifold to help keep it a bit cooler. I know I am definately running stock injectors I had them ripped out, cleaned and tested for flow. All were flowing well and had excellent spray patterns and I'm also at only just touching 70% duty cycle on them. It will be good when I finally replaced the stock manifold and find out what the turbo is capable of with perhaps 1.2bar on the dial, just to try it out and then do the pistons to make sure its going to hold together :( Nice figure paul... *sigh* I dont think I'll ever catch you. :D
Hi Steve.... This is not really an experience thing, this is simple mathematics. Fuel is calories, calories equal power. There is no substitute. You can stick more air in, you can do it more efficiently, you can do whatever you like, but in order to make more power, you need more fuel.
We have had 4 models of Dyno Dynamics, and I can tell you our operator got a reading 10 times that which the engine was possibly able to deliver. Just 'coz its a DD, doesn't mean its always perfectly accurate. The human element can over-ride the electronics in a multitude of ways.
If I wanna get a DD to read high, I can alter the "eletronic settings", but that shows up on the bottom of the screen in shootout mode. But, I can alter the "physical settings", and that shows up nowhere. It's as simple as popping the cover and standing on the load cell.
I assume the DynoJet is hub driven (no rollers). They obviously show higher readings because there are no tyre and roller losses. Our experience has been about half, this would be the equivalent to 190rwkw on a DD. Seems about right to me.
Hope that makes sense.
Answering Questions on behalf of Paul,
Mods,
GT30,
Custom exaust manifold,
Greddy plenum,
910 fuel pump,
Malpassi fuel reg,
Front mount,
twin plate clutch,
exaust,
blitz filter?,
Wolf ECU,
And a whole heap of stickers, and a BIG RICEY wing :D
Did I miss anything, Paul?? (hope you don't mind me givin away your secrets)
I think maybe pointing the finger at the flow rating on side feed fuel injectors might be in order. I mean when people say 370cc or 550cc for any injector that rated delivery is particular to some kind of set pressure and fuel flow delivery. The fact that increasing the fuel line diameter from whatever to 1/2 inch can yeild additional headroom for fuel systems at the final delivery point speaks to some of this issue.
Simply 'flow testing' at your injector service center can't tell you the delivery potential of that injector in your vehicles enviroment. It is a fact conected to properly setting up the right fuel jet on a nitrous system. Each jet, although sized according to the hole diameter must be flow tested against the flow jet on the point of connection to the fuel system.
Anyway anyone like to have a go at the standard for injector sizing?
Hi Guys. Injector flow benches have the capacity to alter flow rates and pressures. This is the same as larger fuel lines and a higher flow rate, pump. So on the flow bench, we can duplicate any condition. SO, lemme tell ya, increase the flow from the pump makes no difference to the flow rate of the injector, as long as the flow rate from the pump is GREATER, than the flow rate fron the injector. THE only thing that increases the flow rate from the injector, is increasing the pressure.
At 38 psi R33GTST injectors always flow 370cc's, + or - 2%. Increasing that by 2 psi increases the flow rate to around 380ccs.
Hi Rob77, I'll post the flow rates of all the fuel pumps tomorrow when I get to the shop.
Hope that helps.
Sydneykid, I'll get the plot of power vs AFR's for you tommorow and then post it up, to see if that helps your calculations. The injectors are definately standard, as there the right colour, and if they were 550cc's then I'm sure the stock computer I had in there when I bought it would not have like it at all:D
As far as the dyno reading high: It was in shootout mode, so all the figures are there, all adjustable settings have been removed so no fudge factors can be entered. All cars dynoed on SST's read lower than most other dyno's in Perth, and Dyno Dynamics brought there car and tested it was accurate.
There are a number of other cars making around 350rwhp on stock injectors. Rob77 made 344rwhp (70% duty cycle) with stock injectors and no malpassi fuel reg., so I suggest that somewhere along the line the estimation that the stock injectors only flow 370cc might be wrong:D
Hicks, That's the majority of mods:D
Joel, Go the 910, nice and quite and flows heaps. I have my external, with the standard pump feeding the surge tank.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
