Hi MiniMe, there are a number of ways to look at "engine efficiency". One is that a petrol engine is around 65% efficient in using the energy stored in the fuel it uses. This of course allows for the power consumed in driving the ancillaries (water pump, oil pump, A/C, power steer, alternator etc) and the losses through the drive train. The other 35% goes mostly in heat into the water and oil etc.
The lower numbers (35 to 50%) only compare the calorific value of the fuel versus the power at the wheels. That's why the numbers are lower.
The basis of all these calculations are based on Newton's theory energy can be neither gained not lost, it is merely converted into other forms of energy". Einstein of course disproved this with E=MC2, but for the course of this post I will assume no atomic reactions going on in my Skyline.
What we were talking about in the previous post was the efficient use of airflow ie; how much air is available versus how much the engine ingests. Numbers like 85% for a pushrod Windsor V8, 92% for a modern twin cam 4 valve, 97% for a Formula 1 engine etc.
Simplistically, that means a 2.5 litre engine at 1 bar only uses 4.6 litres (not 5 litres) of air every 2 revolutions of the crankshaft based on the 92% efficiency rule of thumb. Since we know that RB's produce best power around 12.5 to 1 air/fuel ratios, calculating the fuel required is easy.
Hope that answered your question
  • Replies 335
Simplistically, that means a 2.5 litre engine at 1 bar only uses 4.6 litres of air every 2 revolutions of the crankshaft
1 bar?
Is there a forumula to work out the amount of air a 2ltr for example is using at 7000rpm with 92% Effiency on say 10psi.
which has in turn, been disproved, Capt. Accuracy!
ROFL... i'm just causing trouble now.... This is an interesting discussion especially for us cheapskates!!
Keep it going.
Oh and GTST_VSPEC, run the thing will ya? please? give the cheapskates some hope!!
Adrian
Joel, atmospheric pressure is 1 bar, boost of 10lbs is 0.68bar, added together is your multiple factor for the capacity (or absolute pressure - which is quite often the way turbo compressor maps are represented), so 2L engine times 1.68 is 3.36L of air (per 2 revolutions). With a 92% efficiency, multiply by 0.92 = 3.01L (3.091) of air for every 2 revolutions of the crankshaft.
divide 3500 (for 7000rpm) by 60 seconds = 58.3 (induction strokes per second) times 3.01 litres of air = 175.48 litres of air per second at 7000rpm.
A/F ratio of 12.5/1, so 12.5litres of air for every cc of fuel, the engine would require 14cc of fuel (175.48/12.5) per second, or 50 litres of fuel in one hour (0.014L x 3600seconds).
Also an RB25 at 7000rpm and 1 bar boost would consume 268.3 litres of air per second, so 21.5cc per second or 77.4litres per hour.
I hope those figures arent too far out - perhaps Sydneykid would like to check them for me:D
the only problem is that basic calculations like this dont take into account the density of the air due to temperature and the size/efficiency of the turbo.
there must be a method of calculating the amount of fuel required per hp and engine produces, which would be more accurate.
DISCLAIMER: I really am not sure if these figures are 100% kosher (ie method of calculation), so flame away all you mech eng types etc :D
An internal combustion engine dispenses with most of the energy in the fuel through the exhaust (30-40%) or the cooling system (30-40%). The rest (30% at best) goes into the combustion process to drive the crank. Mind you the combustion process is irreversible in nature (the products cant be recombined to form the constituents) and also governed by the laws of thermodynamics. Add in the fact that you also have the drive train losses to contend with and the petrol IC engine starts to look pretty shit indeed.
Guest INASNT
Originally posted by GTS-t VSPEC
Adrian, Trust me I'd love to run it down the strip, but on stock internals I'm not sure if it would cope. My suggestion is not to be in too much of a hurry to change injectors until it's really necessary:D
Just run it atleast once with some nittos, the engine wont be that fragile that it will break after one run
As clear as you suggestion is, i think you fail to recognise the risks associated with it. As it was mentioned earlier a fuel reg is a band aid solution for a need of more fuel, in most cases marginally more fuel. Running the pressures that you are running on standart fuel lines would not be advisable to anyone.
That's the thing; the engine does not need to be fragile to fail at those conditions. Unless you are prepeared for the worst, the outcome will leave mental scars for a while. :)
On a different note, i am detecting a bit of a dig and sarcasm towards SydneyKid. Is there a reason behind this ? Am i missing anything ?
We love Sydneykid, he's a fgreat guy and knows heaps of stuff, doesn't mean we can't pull the piss out of him occasionally:D
Emre, Rob77 is running 344rwhp with no fuel reg and standard injectors (70% duty cycle), so my suggestion is why would you change them if it's not necessary.
I'm a touch lost here (whats new though haha) so what your saying is you've now got all this power but you are to scared to run the car down the 1/4 because of the stock internals
If thats right whats the use in having the power then? hahaha you can't use it?
Originally posted by Steve
Because he can:)
:bahaha: Thats a good one, Its a damn shame we wont see any times to back up that power then, In my book it sort of defeats the purpose of having power if you can't use it or show it down the 1/4, but I guess its ok if you just want to be a DYNO QUEEN :)
Hi Steve you should have finished the calcs.............
21.5 cc per second at 14.7 psi = 24.9 cc's at 17 psi
+ 20 % enrichment (acceleration, cold run, start etc) = 29.9 cc's
6 cylinders = 6 injectors
60 seconds in a minute
299 cc per minute for each injector
Looks OK for a 370 cc injector?
Except that is at sea level, at 0 degrees C and 0% humidity. Not gunna happen on a roller dyno in Australia. That is unless someone has their dyno in an environmentally controlled room (ala F1).
So let’s deduct some;
Humidity, say 25% (it's not raining)
16 degrees C (not too hot, not too cold) that's 10% (5% for every 8 degrees)
Let’s say the dyno is at sea level, so no adjustment required.
299 + 25% + 10% = 411 cc's
Oooops we ran out of injector capacity.
None of these calcs are perfect, but I have used them often for working out approximately the right size injector, I then add 30% or so to be sure. So 411 + 30% = 534 cc's. For this engine at that power, a set of 550 cc injectors would be my starting point.
You can do this a number of ways, a good rule of thumb used by many in the automotive business is 1.7 bhp per cc of injector capacity. Thus 1.7 * 6 * 370 = 377 bhp.
So, I'm still perplexed..........
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
