Originally posted by Steve-SST
Its a worry but i have seen many so called Hiflows not match the standard one so be carefull. Best thing is to find the extra cash for a proven after market job.
Yeah, Thats why im looking to get a HKS2530. SkydneyKid thinks they are the bees knees and are a better alrounder than the 2540.
  • Replies 335
Originally posted by BOOSTD
what size outlet does your high flow have??? and when does it make 15psi? Exhaust A/R ??
Funny you should mention that boostd, I've asked them on a few occasions what the specs were on my high flow and they said they didnt know and would have to ask Precision (the company they sent it off to to get done). I havent got an answer yet.
It makes 0.8bar at about 4k, under that it feels doughy
I mentioned the turbo you built (I read the thread about your turbo build) and they said it wasnt a good idea to go down that path. They would sell me a brand new HKS2430 or 2540 for $2500.
I'm currently wondering what to do.
That $2500 for a Bran new HKS turbo sounds a little strange. Bran new HKS turbo's are in the 4k range. Never have I seen anyone who can sell them for in the 2k range. I have seen second hand HKS turbo's from around 1500 right up to 3000.
So maybe he means its new to you but second hand.
You can get a GT30 500hp for $2300..
Then there's the external wastegate and on the list goes.
MRK25T, Damn mine makes full boost(1.2bar) by 4k, so a good hi-flow should spool-up quicker. I'd suggest getting it tuned somewhere else just to make sure it isn't the tune giving you the low power, other than that a new turbo looks to be on the cards:(
How much does it cost to upgrade your exhaust housing? My compressor is fairly beefy at .6, but the rear looks a little small. Not sure of the size but it's noticably smaller than the front.
JimX, Be careful when trying to mix and match turbo housings etc, as the results aren't always good. Best to get a compressor map made to see what the turbo will be like before you put it on. You can get really bad compressor surge if there not matched properly:(
I think I already have compressor surge :P I've been given this advice by someone who had a similar turbo to mine, but better matched:
t4/t3, to4 compressor with a h trim wheel, vl turbo .63 exhaust housing with a copy of a sierra t3 wheel.
I'll see how I go with what I have anyway, I might not have a bad turbo afterall but the PowerFC tune will determine what's wrong.
lol, I am exausted :P
I got a Wolf 3D V4 but it isnt installed yet and by what you have said GTST-VSPEC I am over the moon, I looked at a power fc and the Wolf 3D has much better features (IMO with MAP, etc) and also laptop tuning.
Good discussion guys!
/me sleeps
Evan
Hi Steve, maybe you should raise it, I would be interested in his comments.
Hi rb20 calais, I'm sorry but I can't see one area where the Wolf is better than a PFC. In a whole lot of areas it is deficient. The cold start, cold run, idle compensation (air con, power steer, electirical load etc ), closed loop cruise fuel economy, adjustable knock warning, injector load warning, adjustable acceleration enrichment for amount and decay at 5 load rpm's, adjustable water temperature correction, 40 boost versus rpm load points, etc etc
As for deleting AFM's, the truth is there is simply no better way to measure how much air is going into the engine. A MAP sensor merely measures pressure and extrapolates airflow from there, thus is nowhere near as accurate.
As for the lap top bit......... the truth is you use the lap top tuning ability very rarely, when you tune the car. But I use a Commander everyday, they are mounted in the cars permanently. Add up the cost of the digital gauges that you don't need 'cause you have a Commander.
Not that there is anything wrong with the Wolf, but it can never be as good as an ECU that is specifically designed for the car and that uses ALL the standard sensors.
Hope that explains my position
FC-EDIT I think it is called made by some blokes over in NZ. PowerFC tuning from Laptop.
I don't think it supports the R32/R33 GTST's yet but its getting their.
It isn't that expensive either especially if you are a workshop.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
