Brand New Kkr430 Turbocharger Rrp$849 Need It Gone!, Rrp$849, Selling For Cheap!
Hey guys, I got a brand new KKR430 here just sitting at home, l was going to install it on my (to be) skyline, but situations have changed and l will be investing the money into an apartment =D
Taking advantage of the 14k first home owner grant!
Anyway, lm going to sell the turbo here, it is BRAND NEW and basically hasn't even been taken outside of the box
SPECIFICATION
Responsive turbo upgrade for RB20 and RB25
This is our most popular Kombat-series turbocharger, offering excellent response and overall performance on Nissan RB20DET and RB25DET engines. The turbine is bigger than on a 380, but a 0.56 A/R exhaust housing promotes quick response. It is a good choice for 2.0 litre to 3.0-litre engines. It is also good for twin-turbo applications on 4.0-6.0 litre engines.
Specifications
Compressor side
Inlet pipe 70mm, outlet pipe 50mm 48 trim compressor; inducer 53mm, exducer 76.5mm
Exhaust side
0.58 A/R turbine housing, Turbine wheel outlet 48mm, outer diameter 64.5mm
Results
As a single turbo on a 2.5-litre Nissan RB25DET engine we have seen 240kW at the wheels with 15psi boost.
Accessories
The KKR430 comes complete with a stainless gasket, banjo bolt for the oil feed and gasket for the oil return. The exhaust outlet features a 2.75-inch V-band flange to make the dump pipe easier to fit. The turbo comes complete with the V-band itself and a V-band section so you can make your own dump pipe.
(THIS INFORMATION HAS BEEN TAKEN DIRECTLY FROM OTOMOTOS WEBPAGE FOR REFERENCE ONLY)
Also, lm open to offers, l want as much deposit as possible for my new property.
ASKING PRICE $720
Edited by mr33gts4
Free Bump.
These are not direct replacement,
will require mods to intake piping, water lines, dump pipe, and maybe a spacer on your exhaust manifold.
For the price these are a really good turbo. I am running one atm.
RB25det
stock injectors
351hp @ 17-18psi.
Yes I have other mods, but they are still a good turbo!!
Good luck with sale.
  • 4 weeks later...
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
    • Not a huge update because still waiting for some fittings for the intake. But I did corner weigh the car, its enough to make a GTR driver cry at 1163kg (race ready except no fuel)  Sorry about the terrible pics but I think they are readable With 70kg driver
    • The bumper you're talking about looks like this:  Rear wing is this different version which is more GTR-esque:
