*Full house trimatic fresh built by Promatic transmissions, this is the box u need for 10s high 9s, bellhousing fits RB30, selling because i bought a 2 speed glide and big turbo so im aiming for low 9
Parts listed on receipt:
V8 trimatic
1X Trans Brake valve body
1X bell housing to suit RB30
6 plate 3rd clutch
8 plate 2nd clutch
1X tornington bearing for pump
Set reverse clutch pack for trans brake
Frictions on raybestos
New bushes, o-rings, gaskets etc
1x kevlar rear bend
Modify pump
Machine all surfaces
* 8" TCE 3500 race converter 7 dyno runs old very responsive cost me 1.4k
(converter can be adjusted at TCE to any stall speed or engine for $200)
* B&M Pro ratchet shifter to suit Trimatic with brackets and cables
* Micro switch with cable for transbrake
* trans cooler and lines
box costs 3.5k, converter 1.4k, shifter 350...
everything would cost around 5.5k to get it running from scratch
$4000 for everything
( for different engine you will need a tailshaft and bellhousing)
pm or email [email protected] for any information needed
Edited by josip
https://www.sau.com.au/forums/topic/263096-3-speed-trimatic-400kw-gearbox/
Im after $3000 now for the whole lot, need cash to pay off my glide, tested after a rebuild and converter spooled 20psi on 5000rpm with transbrake, that will lift wheels up with slicks.
So you get:
550 + rwhp rated Trimatic with RB30 bellhousing, wirring for transbrake and trans cooler( rebuilt box) will fit rb30 block or needs different bellhousing for a different bottom end
TCE stall converter custom order by RAJAB racing rrp $1400
B&M pro ratchet shifter with cover, cables and brackets
$3000 0423 666 053
I only have a pic of shifter and transbrake switch, everything was still under a car b4 rebuild.
http://i38.tinypic.com/2lkqhoi.jpg
http://i35.tinypic.com/205ck2f.jpg
and this is how it looks inside a 10 sec 180sx with same box,
http://i269.photobucket.com/albums/jj70/Tu...04052008006.jpg
Edited by josip
