Yeah man, parked up in the shed now. Had to clean up all my GTR bits to get it in.
Going to restore back to orginal condition, it's a little to good to Hotrod.
You'd be surprised at the amount of parts still available for it.
Started cleaning up the fuel system, the old fuel had dried up in the pump making a nice gooey mess. Got the right spark plug socket for it today so will be checking out the plugs later.
  • 3 weeks later...
Very nice. . make sure you get the ARRROOOOGAHHH horn for it though lol
i just pissed myself laughing after reading that hahahahhahahaah fkin gold!!!!
as for the restoration, goodluck! should be awesome :down:
thats a good looking buick, my old boy has a couple of 27 pontiacs, that i imagine when together would look very close to that, wooden roof frame and all, saddly his are rusted piles of ass at the moment he plans on resto'ing one day
he's been denying my desire to rod one for many years, so he better do something with them or ill just take one off his hands and do itttt
27 pontiac huh, that would probably be identical to the buick and maybe even share parts. Both coming from GM and all. It never ceases to amaze me the amount of old cars people have tucked away in sheds somewhere.
I'm in Tanzania at the moment so not much happening with it. We started cleaning up the fuel system thou. Fuel tank was spotless inside which was nice. The fuel pump was a bit of a mess thou. All gummed up with dried out fuel. Pretty simple system, uses manifold vacuum to bring fuel up to a reseviour under the hood and then gravity feeds the carb.
Next will be to clean up the carb and drop the oil. Needs a new wiring loom as most of this is buggered. The wires use a type of fabric sheath rather than plastic so it's rotted off. Believe it or not there is a mob over east that make new vintage looms from the same wire. They even have the template for a 27 Buick. Will get one of these and see if it has spark, add some fuel and find out if it starts. There seems to be a little bit of compression, hopefully theres enough to fire up without a rebuild for the moment.
if you have a list of suppliers for bits of these things, can you drop me a message and ill pass them on to the old boy, it might kick start him into doing something
but the pics you posted up there to me look like how i imagine the ponti's to look, as you say there from the same breed..
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
