The following parts are for sale they are for and off an R32 GTR
1. Complete New EXEDY push type single plate clutch heavy-duty rated upto 300KW @ wheels. $500
2. 2nd hand good condition EXEDY (push type) single plate clutch heavy duty good for at least a year. $250 ono
3. Two standard turbos with dump pipes. $300
4. Two AFMs Air Flow Meters in good working condition (Tested). $300/pair
5. Standard Cam gears. $50/pair
6. Complete Rear Tail Lights excellent condition. $200/pair
7. Flywheel. $150 ono
8. HICAS computer. $100 ono
9. 4WD Computer. $100 ono
10. R32 GTR Intercooler works perfect. $250
All Parts are Located In Sydney.
Postage can be arranged at your own cost.
https://www.sau.com.au/forums/topic/263241-r32-gtr-parts-located-in-sydney/
Complete engine Head in a very good condition the engine had low kms and the car was stock standard, and Yes it has everything including:
Rocket covers,
throttel body,
Plenum & Manifolds,
turbos (in perfect condition) with dump pipes,
Injectors with injector rail and wiring,
Cams and Cam gears
All in excellent working condition Ready to go on a block. $2000
Here are some pics of the clutches I also have HKS BOV for sale and a standard BOV complete with the pipes.
This is the New Clutch it has been modified so it's actually better than the standard and the standard is rated at 300KW @ the wheels, so this one will handle more than 300kw @ the wheels
I also have a Pair of 3inch Xtream Top filter (K&N) Air Pods to suit any car with alloy intake Pipes to Suit GTR afm's. Comes with the cleaning Kit.
High Flow Filter with Extreme Top
• Washable/Reusable
• 1,600,000km warranty from K&N
• Unleash the power within!
$300
The following parts are still for sale they are for and off an R32 GTR
I've discounted some Items
1. Complete RB26 Head in a very good condition the engine had low kms and the car was stock standard, and Yes it has everything including:
Rocket covers,
throttel body,
Plenum & Manifolds,
Cams and Cam gears
2. Complete New EXEDY push type single plate clutch heavy-duty rated upto 300KW @ wheels. $500 ono
3. 2nd hand good condition EXEDY (push type) single plate clutch heavy duty good for at least over a year. $250 ono
4. One AFM Air Flow Meter in good working condition (Tested). $170
5. HKS bov with pipe and all hoses required for fitting $350
6. A Pair of 3inch Xtream Top filter (K&N) Air Pods to suit any car with alloy intake Pipes to Suit GTR afm's. Comes with the cleaning Kit. $300
7. Standard Cam gears. $50/pair
8. Complete Rear Tail Lights excellent condition. $200/pair
9. Flywheel. $100
10. HICAS computer. $80
11. 4WD Computer. $80
12. R32 GTR Intercooler works perfect. $250
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
