The following parts are for sale they are for and off an R32 GTR
1. Complete New EXEDY push type single plate clutch heavy-duty rated upto 300KW @ wheels. $500
2. 2nd hand good condition EXEDY (push type) single plate clutch heavy duty good for at least a year. $250 ono
3. Two standard turbos with dump pipes. $300
4. Two AFMs Air Flow Meters in good working condition (Tested). $300/pair
5. Standard Cam gears. $50/pair
6. Complete Rear Tail Lights excellent condition. $200/pair
7. Flywheel. $150 ono
8. HICAS computer. $100 ono
9. 4WD Computer. $100 ono
10. R32 GTR Intercooler works perfect. $250
All Parts are Located In Sydney.
Postage can be arranged at your own cost.
https://www.sau.com.au/forums/topic/263241-r32-gtr-parts-located-in-sydney/
Complete engine Head in a very good condition the engine had low kms and the car was stock standard, and Yes it has everything including:
Rocket covers,
throttel body,
Plenum & Manifolds,
turbos (in perfect condition) with dump pipes,
Injectors with injector rail and wiring,
Cams and Cam gears
All in excellent working condition Ready to go on a block. $2000
Here are some pics of the clutches I also have HKS BOV for sale and a standard BOV complete with the pipes.
This is the New Clutch it has been modified so it's actually better than the standard and the standard is rated at 300KW @ the wheels, so this one will handle more than 300kw @ the wheels
I also have a Pair of 3inch Xtream Top filter (K&N) Air Pods to suit any car with alloy intake Pipes to Suit GTR afm's. Comes with the cleaning Kit.
High Flow Filter with Extreme Top
โ€ข Washable/Reusable
โ€ข 1,600,000km warranty from K&N
โ€ข Unleash the power within!
$300
The following parts are still for sale they are for and off an R32 GTR
I've discounted some Items
1. Complete RB26 Head in a very good condition the engine had low kms and the car was stock standard, and Yes it has everything including:
Rocket covers,
throttel body,
Plenum & Manifolds,
Cams and Cam gears
2. Complete New EXEDY push type single plate clutch heavy-duty rated upto 300KW @ wheels. $500 ono
3. 2nd hand good condition EXEDY (push type) single plate clutch heavy duty good for at least over a year. $250 ono
4. One AFM Air Flow Meter in good working condition (Tested). $170
5. HKS bov with pipe and all hoses required for fitting $350
6. A Pair of 3inch Xtream Top filter (K&N) Air Pods to suit any car with alloy intake Pipes to Suit GTR afm's. Comes with the cleaning Kit. $300
7. Standard Cam gears. $50/pair
8. Complete Rear Tail Lights excellent condition. $200/pair
9. Flywheel. $100
10. HICAS computer. $80
11. 4WD Computer. $80
12. R32 GTR Intercooler works perfect. $250
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
