  • Replies 44
Would you mind PMing me the ACTUAL deal with it Steve-0 if you know?
Wouldn't want Dave to sell the Nur for a mock up :banana:
Tell him to call me if he wants.
BTW using the "search" button on this one will tell you almost all you need to know.
Mines GTR
Looks pretty spot on to me
Here's the real one;
http://www.youtube.com/watch?v=v1_8rvMwhhQ
https://www.sau.com.au/forums/topic/263242-superlap-pics/#findComment-4506837
