i did the change. also went from a pfc to a wolf v500, with a much more in depth tune so i can't really coment on possible response loss, as i actually gained a lot of throttle response.
only ill effect i noticed was a small increase in the amount of times the car cranked over before it started. like maybe half a second.
There are many automakers who use MAP based systems with no problems at all, so why would you have problems with a map based standalone? If there were problems you can probably chalk it up to bad tuning or just a poorly designed standalone. I have zero problems with my standalone map based system even though I have a 5bar map sensor. Cold start, Drive-ability, Closed loop wide band Cruise, and deceleration are perfect.
Edited by maximajim
I went from ECR33 PFC L-jetro and converted it to run the GTR's D-jetro, Being that I mapped both setup's I can say this, the D-jetro was much easier to get nice dead stable AFR's, Drivability is better and fuel consumption is up by .5L better per 100km. (this was with no other mods done at all besides ECU change, I use FCedit, dual widebands, EGT and dual knocklinks when mapping RB's)
Best thing, no idle mess around! car just runs better all round. D-jetro's idle stabilization by timing is fantasic as well! almost as good as VEMS's
so far then .. it sounds all good.
I wasn't told map has any "problems" but that it isn't a good choice if you plan
to do mountain driving, as altitude (or big temp changes) muck with the tune vs maf.
My tuner says map will "feel different" in a possibly negative way, he didn't elaborate.
And people on sau have posted before that map is 'for race cars' and maf is for street,
and someone else on sau said map didn't work as well with multiple throttle bodies.
So I figured I'd ask if people had experienced a car before vs after with as much else
the same.
Edited by moneypit
I would say buy a ecu based on his recommendation or find another tuner who is competent in tuning a map system.
He should know that a good standalone will have temp and barometric trims (if needed).
He recommended going map, ecu is hks f-con,
but he just said it will feel different, and indicated I might not prefer it.
MAP sensor here too. Given the choice, i'll always go MAP over AFM. The number of AFM related issues that seem to pop up all the time is crazy. I went through 3 AFMs on my old car, and it still never was quite right.
100% agree
MAP user here :D
the same.
The issue with multi throttle bodies and MAP, is the turbulunce.
You can get the same MAP reading, for a different throttle reading, and it plays havoc.
Good ECU's, like the Adaptronic, Motec, (I also believe Haltech, ViPEC and Autronic) run MAP vs TPS tuning.
I run MAP with the Adaptronic, and it has no issues at all.
Actually, it has quite a few benefits... I can run NO BOV, and not have a single issue.
I run an oil coated air filter, and not have it flood my AFM giving shit readings, resulting in poor idle...
Yeah mine doesnt take long to crank, and doesnt hunt on cold start. It does everything "normally" compared to an AFM based ECU.
....Well, except for having dramas when the AFM's get dirty and play up :D
Ford XR6 Turbo runs map and no issues there. So the whole map = race car is a little off.
The 1JZ and I believe 2JZ also run MAP...
Lots of manufacturers cars run MAP from the factory
My car takes a couple of cranks to fire, but that is purely the ECU, and NOTHING to do with it being MAP based.
Brand new each time or 2nd hand? I'd be interested to hear the reasons why 3 brand new AFM's would have died in a short period.
If 2nd hand, then well... thats pretty much a pointless statement :D
Every AFM that i put in (new) works/worked fine without issue.
Ive played around with 2nd handies lately (due to time constraint) and had nothing but problems, but i accept that because im playing around with used parts and not brand new ones.
That said - go with what the tuner reccomends. He is tuning it afterall...
Straight MAP was poor on light throttle compared to AFMs but I had multiple throttle bodies (RB26). Redid the tune with MAP over TPS (combination of the 2) and found driveability every bit as equal as stock AFMs.
Best point => if I blow a cooler pipe/vacumm hose at the drags I can drive it home as is... unlike AFMs which would instantly foul the plugs. Best move I ever made was getting rid of the AFMs.
I went for a MAP because my tuner prefers it, he put it this way to me, although the AFM is a good bit of gear he has had more problems with that one piece of equipment than any other but finding out it is the AFM to be the problem is the real reason he prefers the MAP sensor, as for driveabilty I didnt really notice anything except the power increase.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
