My latest project
Sold the EVO VII because yes it was quick with brilliant handling but soooo boring.
I want to be the one who makes the car handle not a team of engineers with a super computer
So here it is it all her "glory"
Lot of work to do yet
Couldn't stay away from a Skyline long (and always had a thing for R30's)
https://www.sau.com.au/forums/topic/263283-project-30/
dam man thats a nice DR30, is that the gtr or the gtr-x?
Also if you dont wont ne of ya parts that u upgrade give me a holla hehe would love to inter change some dr30 parts onto mine!
Check my project 31 out and tell me if it is actually a 31 or a 30.
I also if you need ne parts direct from japan let me no i have a few website up me sleeve for ya, if need be!!!
https://www.sau.com.au/forums/topic/263283-project-30/#findComment-4507131
i was actually just readin up on the dr30s last nite wen i was postin! yeh the RS-X was the top dog with the rb20 early model and there were produces only 200 of them!!! so u got ya hands on a veary rare dr30 bro!
That model was produced between 1984 and 1985 only a year of production cos only 200 made!
And it was said that they are worth more then the R33s to this day so u lookin at sittin on a gold mine of about 14+ already haha
https://www.sau.com.au/forums/topic/263283-project-30/#findComment-4508494
no rb20 in the dr30.
dr30 ran the bullet proof fj20 (4cylinder 2L turbo) and there was more than 200 of them made.
Most of the dr30 were RS-X
https://www.sau.com.au/forums/topic/263283-project-30/#findComment-4508835
bugga cant remember the site i was reading about them!
Well one of the old dr30s had only a few produced and im sure it was sayin theey ran early model rb20s....
If only i new wot the site was again.
But yeh i new that the other model dr30 was runnin the fj20 cos on www.r31house.co.jp thats all they stock in there shop. But also that i one of the websites that is really good for dr30 and r31 parts... If u cant read jap then google... website translator and then copy and paste the website link to be able to read it
Good Luck with the build man
https://www.sau.com.au/forums/topic/263283-project-30/#findComment-4509809
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
