Car Photoshoot 5th April
If you have a Nissan from Japan and model year is from 2016 to 2024, just say you have an Infiniti Q50 4 doors... Why are telling you have an import?
It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…) photo: https://files.fm/f/k9pdug38uq
