  • Replies 101
beat me too it!
I'm about 30min from Garden City (driving at 2am with every green light), are NORTHSIDER's welcome? :blink:
I'm in Alexandra Hills.
And Chris - you can be my date, that way no one will get into a clan war.
i bring mine along sometimes, if she wants to come she comes... :)
pfft, sook....
I bet she does :P
Suck my waxed testicles!!! Border loop in 2 weeks bish.
how come i never see any of u guys... and girls?
They are probably turning into the street that you turned out of, if you look around faster you may see them!!!
So what Im going to do, as the long weekend is a holiday for the boys at EFI and there new dyno ison its way, im going to psot up the cruise date in the events section for a months time, as to have it all planned a bit better, we could even see a dyno day if were lucky. Please post your attendance etc.
I'm from Brown stains but wouldn't mind chin wagging with whitey again seein he has my brakes on his VL.
Ill bet im working though as I usually need a months notice cuz my rosters suck
hey mate is a month from now :)
Bill i put those brakes to good use mate.
VL will be here on the day for you too look at.
Looking forward to seeing your K-line.
WHITEY
HAHA! Another stainer!
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
