"Specs on the LC-1 Stand Alone Wide Band Controller:
The LC-1 is a complete wideband controller built in to a sealed cable. It features the same award-winning patented digital measurement principal found in the LM-1, and includes digital input, output, and 2 programmable analog outputs."
It can either replace your existing narrowband sensor and be configured to output a simulated narrowband, or otherwise it comes with a bung if you wish to install it in addition to your existing sensor.
Many people comment on forums about the reliablility of these units. 99% of problems stem from people not grounding them correctly. Rather than ground it to the body, it should be attached to an ECU ground, problem solved.
The kit is completely brand new. I was going to install it to assist with tuning my SAFC but we barely use the car now and I'm struggling to find the time, so no need to have this sitting around doing nothing.
$250 + post.
I'm on the Gold Coast.
https://www.sau.com.au/forums/topic/263369-innovate-lc-1-wideband-kit-bnib/
Hey Mate,
You interested in $250 including post?
Send me your phone number if it sounds good.
George
$250 + post.
sooo how does this bad boy work?? i mean... where does it tell you what the afr is... do i need to get a seperate gauge etc. or does this plug into a lap top?? i would like it to keep an eye on my safc tune and be able to change it on the road, for different temperatures, fuels, etc.
runs a gauge i believe...similar to a TechEdge unit...which uses a lcd display.
they can be connected to the Vi-PEC and consantly alter the tune for a target AFR at each load cell pre-programmed into the ecu.
correct, plus it has a serial output to plug into a laptop running either the software provided or other OBD-II software packages designed to take an input from the innovate units. Innovate are also developing a wifi module to use with your iphone/touch http://www.innovatemotorsports.com/products/ot2.php
you interested or not?
  • 3 weeks later...
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
