"Specs on the LC-1 Stand Alone Wide Band Controller:
The LC-1 is a complete wideband controller built in to a sealed cable. It features the same award-winning patented digital measurement principal found in the LM-1, and includes digital input, output, and 2 programmable analog outputs."
It can either replace your existing narrowband sensor and be configured to output a simulated narrowband, or otherwise it comes with a bung if you wish to install it in addition to your existing sensor.
Many people comment on forums about the reliablility of these units. 99% of problems stem from people not grounding them correctly. Rather than ground it to the body, it should be attached to an ECU ground, problem solved.
The kit is completely brand new. I was going to install it to assist with tuning my SAFC but we barely use the car now and I'm struggling to find the time, so no need to have this sitting around doing nothing.
$250 + post.
I'm on the Gold Coast.
https://www.sau.com.au/forums/topic/263369-innovate-lc-1-wideband-kit-bnib/
Hey Mate,
You interested in $250 including post?
Send me your phone number if it sounds good.
George
$250 + post.
sooo how does this bad boy work?? i mean... where does it tell you what the afr is... do i need to get a seperate gauge etc. or does this plug into a lap top?? i would like it to keep an eye on my safc tune and be able to change it on the road, for different temperatures, fuels, etc.
runs a gauge i believe...similar to a TechEdge unit...which uses a lcd display.
they can be connected to the Vi-PEC and consantly alter the tune for a target AFR at each load cell pre-programmed into the ecu.
correct, plus it has a serial output to plug into a laptop running either the software provided or other OBD-II software packages designed to take an input from the innovate units. Innovate are also developing a wifi module to use with your iphone/touch http://www.innovatemotorsports.com/products/ot2.php
you interested or not?
  • 3 weeks later...
    • Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
    • So, got some bits..   New oil filter housing gasket (main problem I'm trying to fix -see leak above)  While you're in there's: New belts, pulley and tensioners.  Vanos oil line New oil drain valve New water pump and pulley  New fumoto valve (all my cars have these). Some of this stuff seems ok now that I've pulled it out but I still have no idea how old it all is.  The belts looked fine and then I noticed this. Like somebody has hooked it with a pick.
    • As the title suggests, Looking for some comfortable replacement seats that will suit/fit an R32 GTR. Purely road use.  Happy to travel to the Tweed, Gold Coast and Brisbane area. Possibly Sunshine Coast for the right seats. Show me what you got! Thanks in advance.
    • Customer states,I got an oil leak.  Customer was raht.
    • Hi friends, I recently got myself back into an R32 GTR with factory seats. The seats themselves are in excellent condition but the drivers seat is a bit tight for my back and become uncomfortable after about 20min of driving. The passenger seat is a little better so I'm not sure what is going on there, almost as if the drivers seat is newer and has not been worn in.  Anyway, I'm looking to replace them with something thats going to be comfortable for road use.  I was looking at these replica seats from Crank Motorsport however there has been a number of reviews of the company that aren't great so i'm a little skeptical.  https://www.ebay.com.au/itm/185466689021?_skw=r32+GTR+front+seats&itmmeta=01JKS72VG115M2Y3KBGCBCWYDD&hash=item2b2ead15fd:g:cMAAAOSwhhZlsIpK&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKl6v17FmqPFPHrHp4kFm2I9VMAXrpZg5R8sUXH6QLUAkliQu34NiG%2F84PJ05lKf2iGboUiWpWbvHYPYKsT154rul3I%2FaGRskpG8VfgyrwC9%2BdRj7uoDAPGJH%2FVprfvd6pgAN2XmUz6buE9YHvOPCKhtJfsQXhEzwgmVTcIwEkkV0A1r%2FkyJYMmQK0OKLI%2FrM%2FQLzeAOkN9B6WLAPrNyFlml%2FkG%2BYzkTXGJ8LN%2B0NCSLfczQGSYeJqPfvMFMgDL2gOD%2BPWb3sX1D1A6PxY5jqyMGey7zin4sDqrUrA7CpqLLpA%3D%3D|tkp%3ABFBMmriLp55l I also live In the Northern Rivers and these seats are in Melbourne so I can't even try them out before purchase.  Is there anywhere/anyone around the Gold Coast, Tweed or Brisbane area that would have a decent selection of seats I could test out before purchase. A lot of these places seem to be in Sydney and Brisbane. Maybe there's an individual who has an after market item such as Bride or Recaro I could quickly try? Thanks in advance!
