1996 SUBARU WRX SEDAN
LOW KMS - 100, 000KMS
CUSTOM PAINT - BLACK WITH RED PEARL
ALWAYS SERVICED - EVERY 5000KMS WITH 5W-50 OIL.
THOUSANDS SPENT ON MODIFICATIONS
STI (D-FORCE) FRONT LIP
SUPRA REAR WING
LOWERED ON STI ADJUSTABLE CONTROLLER ARMS
LOWERED ON STI SPRINGS AND SHOCKS
STI RATIO GEARBOX FROM 96 WRX STI RA - STRENGTHENED
3 INCH EXHAUST FROM TURBO INCLUDING DUMP PIPE
VF22/SR40 420HP HYBRID TURBO
APEXI POWER FC ENGINE MANAGEMENT COMPUTER
APEXI ELECTRONIC BOOST CONTROLLER
K AND N POD AIR FILTER
BLITZ BLOW OFF VALVE
CUSCO STRUT BRACES
BLITZ GUAGES - BOOST AND EXHAUST
CD PLAYER - PIONEER
SPEAKERS - 6 INCH SPLITS AND 6 INCH REARS
SPEAKER AMP
FRONT MOUNT INTERCOOLER - NOT YET FITTED
GOLD RIMS
LARGE 4 1/2 STAINLESS STEEL MUFFLER
DYNO TUNED
TURBO SMART BOOST CONTROLLER
BUCKET SEATS - FROM 1997 MODEL WRX.
IRIDIUM SPARK PLUGS
BOSCH COIL PACKS
SPARE SET OF TYRES WITH 15INCH RIMS
IMMACULATE INSIDE AND OUT.
URGENT SALE
$21 750 ONO
WILL NOT GET A BETTER WRX FOR THIS PRICE!!!!
PHONE NO: 0413 249 333
hey guys, all pics will be up tonight! will email them to you all.
reason for selling is i am looking at buying a skyline.
running is easy at the moment on only 15psi and its getting 159.4kw@wheels. capable of heaps more with this setup.
with the cooler fitted should be looking at close to 19psi and 190+kw which is a very fast 12 sec WRX.
check www.geocities.com/r33forsale I was originally advertising for 33,000K, but Am now looking for a outright saleprice of 29K or Trade (with cash adjustment)
Also see the thread:
http://www.skylinesaustralia.com/forums/sh...&threadid=23098
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
