Heres the info. I am happy to send to QLD and will cover any postage over $50. Will let the whole package go for $740.
cheers
dave
exhaust specs:
pipe diameter: 80mm (3")
tail pipe diameter: 115mm (4 1/2")
front pipe diameter: 80mm (3")
pics:
hey.. im still looking for an exhust.
dave: i am after in slightly better condition, thanks anyway..
There was a blitz NUR one sold here for $600 that i realy liked.. but i missed out :)
hey n/p if you dont want it - but there is nothing wrong with the condition of this - its actually less scratches than aybee's if thats what you were reffering too.
Also, if you like the NUR exhaust, your best bet would be to buy new as they are only $650 ish new anyway compared to most other brands at over 1k new.
dudes, its a second hand exhaust and all this considered from what I can see its in pretty good condition.
When I was looking for mine I went thru so many damaged exhausts before finding one that was in reasonable condition.
Originally posted by cyco
Is it all mandrel bent? If so and you've still got it in about a months time, I'll be interested in the whole lot!!!
yep its mandrel bent - all name brands are (im 99% sure). Shoot my an email if your interested still later.
cheers,
dave
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
