The HKS cams I had did not have HKS stamped on them and now my TOMEI cams also don;t have any branding stamped on them.
Were they RB25 cams or RB20 cams? RB25 cams have HKS stamped on them, 100%. Tomei don't have anything so don't compare them.
Concaves on the cams mean standard RB25 cams. Another way to tell is that HKS cams don't have a casting mark down the side of the entire cam, stock ones do.
Here's a stock one, as you can see, it has the concave and the casting mark.
Your paint picture is exactly what stock ones look like. Call him tomorrow and tell him he sent you stock cams, see what he says.
Edited by PM-R33
  • Replies 44
HKS cams that I have seen are ground on their own billets which have HKS cast into them. No HKS RB cams that I have seen have the head bolt scallops in them like a standard cam or a Tomei cam, they are full round between the lobes.
YEs the HKS 264 cams I had were for a rb25 but I was using them in a rb20 before one of them snapped did not have any markings and did have the concave bits for the head studs... they were quite a few years old since I first bought them but so maybe they have changed their design over time?
Ive spoken to slide and he has told me that the early HKS cams were unstamped and did in fact have the concaved parts for the headbolts. Here are some pics, does anyone know how to measure the lift properly?? And what standard lift should be in comparison to these? I have just read that both standard rb25det cams should be 240 degress with 7.8 lift on them... sound normal?? I might run down to the head machining place and ask them to measure mine..
have a look at the Rb30 guide pdf file
in there they have the chart from Tomei that lists cam specs for the standard cams in RB engines
according to that:
R33 RB25DET cams should have 240 degrees duration and 7.8mm lift
...so would appear to be standard lift
Edited by Kranker
To all those that were following my story haha..... I ended up getting his contact details off ebay, and calling his home phone as I hadnt recieved any emails back at all. After explaining the situation he agreed to transfer the money back to me. The money has shown up today, so now I'll send his precious cams back to him. Problem sorted. Thanks for everyones input!
Jamie
Jamie
Did he make a mistake, or was he trying to rip you off?
He told me he bought them second hand under the impression they were the early model, non stamped HKS cams. But never got them fitted to his car so didnt know. Honest bloke or decent liar, who would know ???
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
