Im having problems with my idol on my car! when i give it a bit of a rev the idol starts the drop then pick up and just keep jumping up and down like its going to cut out! :S iv got a bigger turbo, air intake, front mount and bov. dose anyone have any ideas?? thanks
https://www.sau.com.au/forums/topic/263427-i-need-help/
Hey Scott,
I have a few points:
1. Was this problem occuring BEFORE you did the upgrade?
2. Is your BOV aftermarket? If it is, is it venting to atmosphere? If it is then thats a BIG NO NO!!!!!!!!!
3. Check out this link:
http://www.skylinesaustralia.com/forums/Di...n+the+aac+valve
It is a mechanical service but may fix your problem (I had to do it)!!!!!!!!!!!!!
Hope I provided some insite for you :ph34r:
Edited by im late
https://www.sau.com.au/forums/topic/263427-i-need-help/#findComment-4507973
yeh i pretty sure thats to atmostphere then mate
if its plumbed back there;ll be a little tube which takes the air from the bov and plumbs it back into the system..
with an atmo it gets rid of the air all together (into the atmostphere - hence "atmosphere") and the afm goes holy balls where'd that air go and shits its self.. (basically :ph34r:)
https://www.sau.com.au/forums/topic/263427-i-need-help/#findComment-4508010
wat do you mean by atmosphere?? i just got a turbosmart bov with that trumpet looking bit on it!
If it is the trumpet turbosmart then it will be vent to atmosphere.
Vent to atmosphere = the LOUD wank/illegal pppssssttttt noise you hear from the BOV in between each gear change!
Mate that can really be the cause of your problem. The stock ECU relies on the air that is vented from the BOV being recirculated back into the intake
https://www.sau.com.au/forums/topic/263427-i-need-help/#findComment-4508028
yer tru, cause wen i got my front mount and intake done they removed the plumb and stuff, so if i put in like a hks ssq bov will that be better for it?
Let me save you the expense by telling you this.
Your stock BOV is PERFECTLY fine for the power level you will be running with those mods.
I am running more than double the factory horse power on my car with still the stock BOVs. All day everyday no problems :D
Put the stocker back in and plumb it all back again into the intake. Keep it legal bro.....don't give the cops a reason to pull you over!!!!!!!!!!!
If your mechanic reckons you need an aftermarket BOV and that you can vent to atmo with your stock ecu.......then they need to go back to the mechanic school 101 class :ph34r::D
https://www.sau.com.au/forums/topic/263427-i-need-help/#findComment-4508057
how can i put the stock one back on wen the hoses aint there anymore!lol iv still got the old bov but wen they did my front mount like i said before the ripped them out!! i want the stock 1 back on!!
https://www.sau.com.au/forums/topic/263427-i-need-help/#findComment-4508082
Whoever did your BOV install MUST give back to you ALL the items he/she took off the car during the install. Every competent mechanic will just pop it all in a box in the boot of your car.
You are going to have to get the original stuff back from them other wise you are going to have to spend some more money to do one of the following:
1. You go to a wrecker and get all the factory hoses, etc to fit the stock BOV back on.
2. Turbosmart should provide as an option part to convert you BOV to return. This means a pipe/hose can be run back to your intake.
To round up:
1. You MUST feed the BOV venting back into the intake.
2. If the problem still persists (unlikely) Clean the AAC Valve.
https://www.sau.com.au/forums/topic/263427-i-need-help/#findComment-4508108
The reason they said u need an A/M BOV is because they were to lazy to make a new return pipe for the vented air (when installing an A/M IC it's easier to put on an AM BOV), If u want the A/M BOV on there clean your AFM, AAC valve and every time your about to stop (going about 5KM/H) give it a touch on the accelerator peddle.. i would recommend going back to to standard BOV as you don't really sound like your that confident working on your car.
Before you do a mod research, research, research.... even if your mechanic says you need to do this, this and this to get ...
Edited by axe s
https://www.sau.com.au/forums/topic/263427-i-need-help/#findComment-4508113
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
