Hi Guys,
Hope that I have secured a bonnet for my car but my carry-all has fallen through. If I can lean on the gracious spirits of the Forum community to help out before I lash and hire a ute for the night it would be greatly appreciated. I will be picking it up on Tuesday night in the city and dropping it off in Cheltnham at the shop.
Please call if you can help out. Can shout you a McDonalds Sundae or whatever your gracious time is worth.
Thanks in advance
Bart
0402 832 655
https://www.sau.com.au/forums/topic/263437-need-help-moving-a-bonnet/
lol last time i picked up a bonnet i drove to the destination minus one...then fitted up new one and voila...job done...nb: this was over west side tho...and we all know how the west is!!!
I may be able to help you tonight if you still need ....( time depending )
I am in Port Melbourne......so can easily jump into the city and then shoot down to Cheltenham as I have to go to Mordy tonight anyway.
If you think it will fit in a Ute and can do it sometime between 5 & 7pm tonight let me know 0411 078 783 ( leave a message if no answer )
Thanks racin8 and mastadd.
No Thanks to you cheeky post jumpers :P
Have sorted a car from work. Anyone need something moved tonight. I am now a MAN-WITH-A-VAN. Already moving a BBQ from South to North then picking up my Hood I hope. Jenno call me please, otherwise all of this was for nothing.
Thanks again guys see you all soon when she has an engine in her.
I didn't realize your car wasnt running LOL...if i had a 32 id def help you out...sorry my whale wont fit the bonnet. However driving over this side minus a bonnet might attract a little attention from the popo. :)
Well all of that for nothing. Dude didn't ring me so waited all night for nothing...... Then had to return the Van....
Well at least I know where and how to get a van...
If anyone else needs a hand some time let me know....
Bart
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
