  • Replies 85
I'm needing a passenger side wheel well liner (left guard liner). Does that come with the mounting hardware (clips and screws?) Also, the HKS piping, are we talking the intercooler piping? turbo side piping? Filters and elbows?
Parting out White R32 GTR. Currently have the front half as a half cut, and the rest is in parts
Fell off road on driver side RH Qtr panel hit bad, can cut off good left hand quarter panel .
Items listed below: See link for pics
Front cut includes 76000 km Motor/Box/Loom/ECU/brake master/Clutch master and slave/new twin plate clutch/ dumps/dash/turbos and just about everything you'll find in an engine bay, except cooler and piping. - $6000 or near offer. DEPOSIT TAKEN on FRONT CUT
Fuel pump $140
Fuel Door $40
Fuel tank $40 SOLD
Drivers Door (Trim+Cont) $50 SOLD
Passenger Door (complete) $150
Rear Reo Bar $50
Rear bumper $200
Rear Tail lights Pair $120 SOLD
Rear boot lid (wing + badges) $250 SOLD
Rear reverse lights Pair $30 SOLD
GTR Steering Wheels x2 $100ea SOLD and SOLD
Left Front Indicator $90 SOLD
Fog Lights (Pair) $75
Factory Cold air box $80 SOLD
GTR Grill $130 SOLD
Front Reo Bar $50 SOLD
Front Bumper (2x cracks) $200 SOLD
Twin Factory Dumps $5 SOLD
Blitz FMIC $250 SOLD
HKS Piping (RB26DETT) $150 SOLD
Side Skirts $150
Set of Side Pods $150
Right F guard (damaged) $250
Left F guard (perfect) $400
Pair Headlights $350
Left Front Guard Liner (perfect) $80
Rear GTR coilovers $150
Front Trust Coilovers $200
Aluminium Bonnet $300
Rear seats $10 SOLD
Glove box $10
Factory Gear Knob $2 SOLD
Momo gear knob $5 SOLD
Rear cradle $400 Deposit taken
Tailshaft $200 SOLD
Rear callipers, rotors $400 Deposit taken
Front callipers, rotors $500 SOLD
Rear sway bar $200 SOLD
Front sway bar $100
Front LCA (pair) $200
Front Upper Arms $100
Seat belts x4 $80 SOLD
R32 GTR Diff $900 Deposit taken
Radiator $175. SOLD
PICTURES : http://img291.imageshack.us/gal.php?g=dsc01036.jpg
Either PM me or call on 0403 071 294.
Located in The Gap, Brisbane. Would prefer pick-ups, but talk to me. Bulk buy discounts a specialty
Thanks
Radiator is SOLD.
Bonnet is the one in the pics, but very hard to get a pic showing damage, i will need someone who's OK at ally work to repair.
Bonnet closes and locks . Best to come and look at it ( Adelaide's a bit of a drive but!), sides postage/freight to SA will be a killer!
Hi mate.. intrested in the reo bar and the grille
does the grille still have the clips ??
and the reo bar looks a little twisted... wat's the condition ?
and can u post a better pic please
PM me.. thanks
PM me.. thanks
Sorry reo, front bar and grille all been sold
Dude that put deposit on front cut, box, diff cradle rear brakes and front knuckles has pulled out.
So
Front cut rb26dett motor complete/g/box/loom/ecu now back for sale $6000
Diff R32 gtr LSD with shafts ATTESSA and pumps $900
cradle with brake backing plates all arms $400
Rear brake rotors (almost new cond!) and calipers, $250
Front knuckles with hubs, ABS rings and sensors, cv shafts $250 the pair
Upper eccentric bushed adjustable front camber arms $150 pair
Front lower radius arms with eccentric adjustable bushes $150 pair
Lower control arms with very tight ball jionts, ( car had done 76000kms) $200 pair
do you happen to have rear backing plates for sale?
Yes but thay are all on the complete cradle
$400
Can supply rotors and calipers as well $250
does the gtr side skirts and side pods fit the gtst ??
If the GTST is around 1993 year model, and happens to be a two door, like a gtr, then yes they will fit.
They are some sort of flexible thick plastic that was fitted as standard to the r32 gtr model by Nissan.
If it's a four door, then they may need some trimming (easy with a small grinder like a dremel or 4"jobbie)
And yes, they are all still available.
I can do a better price if youy want both the full set of pods, and, the side skirts.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
