Hey guys this morning i quickly done a search and nothing came up, so here goes.
I have had this problem, under braking (sometime, rarely) the car pulls really hard to the left.
I thought that it could have something to do with the brakes and capilter but the only thing that i really needs is a machine of the front rotors, the pad are still fine (and even on both sides). What puzzles me is that it doesn't always happen, just sometimes. :down:
Any ideas?? The allignment is generally fine, doesn't pull or anything (on the perfectly straight road :bunny:)
Edited by P1OTR
so if it pulls to the left, that mean right one is gone? Can you please clarify wat do u class as a rebuild. Because there are only really seals that u can replace? i replaced the ones in the middle of the caliper about 6months ago
in the middle? by that i take it as the 2 seals between the halves of the caliper itself.
for the pistons to sieze the actual seal inside the pistons bore would need replacing.
its $90 for a rebuild kit for the front of an r33 gtst
If it was me, I would rebuild both sides.
It's cheap and easy.
Why wait for the other one to go, or mismatch the performance??????
Yer i think that i'm gonna do it this weekend. Do i need anything specific? I mean that tools wise.
Many people done it before by themselves, cause i'm a fan of playing with things by myself
Nissan will carry the rebuild kits, just call and ask.
As far as tools, nothing special is required, just the standard.
You'll need to drop the brakes, rip them apart, clean them, put the new seals in, put them back together, bleed them, then drive away.
Too easy.
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
