WANTED: r31 skyline any series (ti or silhouette would be nice)
ITEM CONDITION: running (or able to run) motor, good transmission, brakes and diff intact
REGO: Required? NO
PRICE:
CONTACT: alex 0404619395
DELIVERY & CONDITIONS: i can pick up
PICS: Required? no
has anyone got an r31 skyline of any series lying around they are wrecking or want to get rid of? silhouette or ti model would be good for the lsd
i can come get it and take off ur hands... i just want the front struts and brakes. motor, trans, diff,
https://www.sau.com.au/forums/topic/263489-r31/
REGO: Required? NO
PRICE:
PICS: Required? no
Hey mate
Got a s1 Wagon
got a lsd fitted
5sp
unreg
Rear damage but driving
PM me for my number if your keen
Located on the Northen beaches
https://www.sau.com.au/forums/topic/263489-r31/#findComment-4512875
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
