(r34)
Hey Guys,
Went to get a tune yesterday But fuel pump Shat itself on the dyno
Running a
Highflow rb25 turbo with apexi SAFC computer running 1+ bar boost.
Full zaust and the ect..
So got the Walbro 550hp fuel pump thrugh it in last night.
But the car is still running like shit Idea's really lumpy,
and seems their is no fuel pumping through.
Maybe
Air Still in the Lines ?
Fuel pump Not right ?
Still needs the tune to fix the problems???
Whats urs say , thankyou
-Ricca
https://www.sau.com.au/forums/topic/263493-fuel-pump-help/
If your stock fuel reg has passed away, this may cause the problem if it's starving for fuel.
I would guess that the car's fine until you start to put the foot down which is where she starts to fart, yes?
It make sense to me as the reg is not holding back the fuel to pressurise the rail.
Other things I'd be inclined to check is for a dirty fuel filter and/or fuel tank, and whether the pump is seated correctly (not accusing anything here).
https://www.sau.com.au/forums/topic/263493-fuel-pump-help/#findComment-4510845
All Sorted Guys, i Did everything right Problem was,
Day before NeW fuel i had a tune and was running rich,
When i through my knew Fuel pump in it was still reading as the old on so Running like shit.
Went and got a tune and its all fixed,
With a Shit Clutch , Shit SParks, and a Zaust with wholes
Ran 10psi 294 HP at the Rears
Not to bad,
Should get over 300 next week .
https://www.sau.com.au/forums/topic/263493-fuel-pump-help/#findComment-4511161
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
