Put your stock exhaust back on, install a shitty cat converter (So a non high flow one) and put in a resinator just before the rear muffler.
Test it and see how you go.
That should shut the F**king EPA up.
  • Replies 49
he did test it in the open, it was outside in the carpark area at 9.30 am very little traffic, and he did it like 3 or 4 times.
in reference to ur quiet/sport mode question my 34 has a swith under the dash from factory to make the exhast go louder or quieter by directing the exhaust gas into either side of the muffler (one is fatter and one is skinner)
lilydale is a big drive for me but it might be worth it i guess because my car is not really loud at all
That sounds like a Varex muffler or something, never seen that stock on a 34 GTT. also, why the hell did they make you rev it to 5000rpm? when mine got tested it was to 4000-4500rpm from memory
Edited by Weapon
yes they can its happened to me twice now, once for my supra na and now the 34, the supra however was f**king loud lol. na with extractors and a straight 3 inch pipi no cat and 4 inch muffler
na supras are the lodest things around with even a small exhaust..... friend at work has it with just a 3.5 cat back and it is atleast 3 times as loud as my turbo back 3-3.5inch....
i recon it also has to do with the type of metal used..... my fujitsubo exhaust is actually very quite compared to similar exhaust made of different material....
All NA cars are loud because the turbo stops the exhaust resonating.
it is the stock exhaust dude. it has the cat in it from compliance.
i have a resonator and a muffler in my boot which i will be hopefully putting on tonight and then testing again in the morning,
How far away from the exhaust tip did he have the microphone?
From your description he had it right at the exhaust tip...
i reckon it was about 50-70cm away and he had it a little bit of angle as well, he had this triangle shaped ruler to measure it (the distance)
Isnt it the Nismo exhaust option that was factory on some R34 GTT that has the switch to swap between the 2 mufflers?
well mine has a swith on it just under the steering wheel is says sport and quiet ( i think) i honestly cant tell the difference between the 2 setting until high revs really. i left it in quiet mode for the test obviously.
Cool!
Get the resonator and the muffler put on and see how you go...
You will probley find that the exhaust will be very restrictive, so don't hammer it too hard.
Untill you goto the EPA and let them rev it, pass the test then free it up again.
I'm sure someone's posted the link to this file before but no harm doing it again. Heres the file for the ADR standard used for testing exhaust to 90dB.
ADR_28.01_FRLI_Mar_06.pdf
Maybe I should bring my car to have it tested by someone to see whats the dB level. I really have no idea how does 85dB and 95dB sound like on a car. How much does it cost to get it tested by someone anyone knows? Or getting those dB meter on ebay (50bucks cheapass) will do the trick? I'm probably hijacking the thread but does anyone know if the Trust Ti-R come with a baffle? Mine seems to be straight thru and someone told me before Ti-R arent that loud to begin with. Heres the spec provided by Trust.
From the looks of it it should be on the 94dB level but my friend who's heard it told me it'll probably be 98 or even higher (I'm thinking its the baffle that was removed). And also does being an N1 affect the noise...?
Let me know what you've done as I'm really looking for alternatives to current exhaust or modifying it to a decent dB level (90-92 if not below 90). Cheers!
the test was $35.00
dont weld anything into your system. you know that security screen shit that some backdoors ect. have, its metal with lots of little holes in it, get some of that or something similar, cut it out in the shape of a gasket and stick it somewhere in your system, and dont thrash your car when your restricting the exhaust system also. i was speaking to the owner of an exhaust shop and he told me this is how all the big v8s get over the pits.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
