Iv just put a Power FC ap engineering ECU on a r32 with a rb20det and the car wont start. The Fuel pump does not turn on and the hand controller will not turn on.
But if i put the stock ECU in it works and the fuel pump will turn on.
Any ideas????
Thanks
Steve
https://www.sau.com.au/forums/topic/263514-power-fc-help-wont-start/
what's the product code? someone on here can tell you if that pfc suits your car? and did you buy it new or s/h?
its the right one, iv opened it up and it says rb20det, and its been seen running in another car over a year ago.
iv got a feeling its been fried?
Thats exactly what my one did when I fried it (put the battery terminals on back to front in a moment of insanity late one night)
Fuel pump wouldnt prime at all and hand controller would not turn on, I ended up getting it fixed but I cant remember the name of the company that did it, ill post in here if I work it out :P
that would be great!!!
Tested the ecu on another r32 and it works fine, so i dunno whats going on with this car????
we generally can repair these units when the polarity has been reversed.
but that seems to not be the issue...hows your battery?
Edited by DiRTgarage
i had this issue in my car, turns out it was to do with the 12v constant power to the pfc. i now have the issue of constant 12v to injector 1 which is stopping the pfc from saving settings.
if ya have someone who has test light and multimeter handy get them to check it out, i luckily had my r32 and my mates r32 side by side and we just compared looms and ran tests on each to isolate issue.
We tested the ECU plug against another r32 that the pfc works on and every thing came up the same!!! and still no step forward. The only thing iv found is the battery light does not turn on when the IGN is on and on the working car the battery light comes on???
check the basics on the r32 where the PFC doesnt work
its likely something simple is wrong (with the car, even tho stock ecu works)
the std ECU is a bit stupid vs the PFC and works with hacked setups
in the PFC FAQ (in my sig) look for a section on the ECCS relay
it shows how a mangle car works fine with the stock ecu but doesnt with the PFC
it shows how to correct it as well, from memory something with the ignition is wrong or theres a fuse missing
  • 3 years later...
Had the exact same issue. only just fixed it. Turns out what the majority of people say is not always true. Series 1 and 2 r33's have a couple of different ecu pinouts. I swapped a couple of pins around and its all sweet!
  • 5 years later...
Hey bud I be done this to my power fcdonyiu or do U know where I can get it fixed?? Any help would be appreciated
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
