Hey guys im in need of a bit of help
ok so i have an S13 with the 5 stud conversion and im using 32 gtr brakes front and rear.
with the 32 gtrs there handbrake assembly is on the backplate of the rear rotors and when i bought the Gtr brakes it didnt come with that, only the rotors, lines and calipers.
so at the moment im running no handbrake and to be able to run one i need to find 32 gtr backplates and put them on and get new handbrake lines.
I have searched and called a couple places and they got nothing for the 32 Gtr.
so what im asking is will the backplates off any of the gtst models work?
are they the same size disc and do they run the same handbrake assembly?
if they do i can easily pick up a pair of 33 ones as there are a lot out there and from what i know 33 ones will fit.
just need a 100% answer if i can get one off here
ok thanks! :P
Maz,
https://www.sau.com.au/forums/topic/263543-skyline-brakes/
I cant be 100% sure, but the earlyer non-Vspec R32 GTR's share the same brakes as the R33 GTSt, possibly the 32 GTSt too.
Maybe you could go into a wrecker and have a look at some?
hey
im pretty sure 33 gtsts have the same also, just not 100% lol
the 32 calipers are different so i thought they might not work at all
i have been to wreckers and looked at some but my 32gtr ones are already on the car so i cant see both and i cant seem to find 32gtr brakes at the same wrecker to compare them
but thanks for your help, i might just get the 33 ones as i have that feeling they will work lol
https://www.sau.com.au/forums/topic/263543-skyline-brakes/#findComment-4510339
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
