I need to get a new set as I only recently bought the car and didnt get around to makin a spare set.... silly me....
That reminds me i have to make a new set.
Either call a locksmith, best off you pull them out and take them to him, or just get a new/second hand set of locks with keys.
Edited by W0rp3D
i kwno its a bit off topic but ... where do u get the keys made .. is it a special key or any locksmith will be able to do it
Not from a skyline, but it may be of some help...
I have a Rover tomcat that I needed to get keys made for, I took the door barrel out and brought it into my local locksmith. They made the key up - piece of piss. But the ignition barrell had an extra tumbler/slider (or what ever the term is) at the key tip, so it didn't work. The original guy at the locksimth wasn't overly keen to help, but I got onto another guy there who was happy to help. He just took a bit off the end of the key - 1 notch worth - didn't work, but I took it back each time for one more notch to be taken off the tip until I was up to the last notch and thank goodness it worked. Now I just have to rebuild the engine :)
So the ignition barrel may have an extra bit at the end to work. May not however, But I thought my method was easier than pulling an ignition barrel out.
Also, if your car is fairly new, it may need a key through the dealer as it may have electronic entry or a transponder of sorts. Other than that, your locksmith is the way to go.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
