Within the up coming weeks im installing a few bits and pieces on my 33 and i was wondering if there are any stores in adelaide who sells the Cooling-Pro Stealth Series Intercooler from Justjap heres the link http://justjap.com/store/product.php?produ...at=0&page=1 or any store that sells this type of cooler. Thanks from Nathan.
https://www.sau.com.au/forums/topic/263567-where-to-buy-this-intercooler/
That specific cooler I haven't noticed being sold my any Adelaide shops. Tho I think ISC may?
I want to nab one soon for my Stagea ... something that looks better with the new bar.
i think ARC or Blitz make those types of coolers as well
and you should be able to get them through places like Autobarn or some of the other import places
but expect to pay a bit more.....
pretty sure we have a want to buy section and a wasteland for these questions, but I need one too, Group buy..lol
need a GTT one with both inlet and outlet on same side, or something like that one. autobarn fail, cost too much for this one
synergy fail, way way too much, 1800 for blitz installed, ya right..lol
I want one of them for my R32, but they don't make them for it and I don't know if it would fit.. :)
I have an R34 GTT cooler and piping mate that I had modded to fit into my 32 mate if you want it? PM if interested. Also a spare R34 GTT cooler not modded. Both in great shape.
Car made 210 RWKW with it so not shabby.
Yeah thanks boys, I think Justjap is my only option and probably cheaper than anywhere else. This question may have been for the wasteland but i lose track of stuff on there too much bs on there.
i have one of these coolers from justjap, they are decent quality and very easy to install. good bang for buck item
Are they worth keeping on the car for a long time ? Would you put them up with other products like Greddy cooler ?
hey mate, I would be going with a Greddy LS cooler. Bolt straight up and dont have that gay pipe underneath.
My mate has a Blitz one and hits that pipe so much. Basically needs a new cooler now.
I can definately vouch for that
at the end of the day it does the job pretty well, and is a very good cooler kit for its price.
If you are going to buy a Greddy one, you know you are buying a quality item - it'll always be voted better of the two kits.
I bought the justjap one as i wanted to use of the standard ic plumbing in the engine bay. no cutting holes anywhere for pipes, no extra piping under the bonnet at all, no removal of my washer bottle. Simply less stuffing around.
yeah the 'gay pipe underneath' does sit a little low. just got to be a little careful, that is all. If you can drive through dips and reverse out of risky driveways in the right manner, you will be fine. carelessness will destroy these fmic kits, end of story.
Yeah exactly thats why i want this type of cooler, Even if i do that have so called GAY pipe going underneath.
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
