Hey all
Im a noob when it comes to this and i dont have the programs but i would like this pic (attached) shrunk to roughly bank card size (credit card size or bit smaller will be fine). Also if at all possible to have the license plate blocked out. Ie so you cant really see it at all.
Any help would be greatly appreciated.
Ben
https://www.sau.com.au/forums/topic/26357-help-plz/
