  • Replies 494
Posted Images
Haven't been up there for 5 years myself, so I don't know.
http://www.hinzedamstage3.com/public_notices.php
Western boat ramp is open, on the Nerang Murwillumbah Road.
Natural Bridge is down that way. Not sure what the road surface is like.
http://131940.qld.gov.au/Road-Conditions.aspx?id=92580
Anyhow, make up your own minds.
I'll be on the road Sunday. PM me if you're interested.
hey i was out there last friday night an the dam is still closed...
an the road out to natural bridge is ok to average some sections have been
resurfaced an are nice an smooth an some bits are old an quite rough but over all a good drive..
super street $ 2200
racing logic $ 1700
buddy club $ 1100
all have the same amount of adjustments an same build qaulity..
I got mine for around 1500AUD delivered from japan. After researching the difference between the jap spec and aus spec one, I concluded that its not worth that extra 1000 (quote by fulcrum around 2.5k) for revalving simply because you cant really feel that much of a difference. In any case, a lot of jap spec ones are around the 2k mark locally too which I think its a very heavy mark up by distributors here.
Also another thing worth noting is, I've read somewhere that ONLY Teins are legal when it comes to aftermarket suspension in Australia. If thats true, I wouldnt mind paying that extra 400 for it. Aus or Jap spec doesnt really matter because they're all green visually (if you know what I mean).
Who did you get them through if you don't mind me asking?
have you screwed some more damper in yet...?
Fixed at 14 front and rear. 28turns in total and at the softest, its way better than stock but at the stiffest, its not anymore stiffer than stock.
and height?
That will be fixed next time I'm back from site. Probably drop another 10mm or 20mm from the front as the lowest point of my car would be the front pipe.
If your car is at 140 now, 20 will be safe at the front if you're scared of the speed bumps. You could go 40 at the rear though. My exhaust doesn't scrape at all and it's a hell of a lot lower than yours.
There hasnt been 1 yet I believe. Maybe try organizing 1 for next weekend or Friday night. I might be able to make it when I'm back from site. I'll probably be doing the major service on Sat and dont know how long it'll take.
  • 1 month later...
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
