Wtd-- R32 Gtst Rolling Shell
WARDY32
 Share
Im on the lookout for a good condition R32 gtst rolling shell to build into a street/time attack car. Im really regretting selling my old one and i wanna build another... Id prefer one in silver but im not too fussy and will get it sprayed. MUST be able to be registered. Doesnt have to be regoed though. Must have complete interior..
Will pay the right price for a good silver one so let me know if you have one
Cheers Wardy
  • 6 months later...
Cheers Wardy
hey mate, i have a black R32 gtst...COMPLETE car minus engine and box...gtr front seats, momo steering wheel, 3 inch cat back exhaust, king springs..only thing missing is the left head light...how much you looking at spending?
hey im in melb and interested in yoyr shell were r u located
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
