Exedy Sports Organic single plate clutch for R32 GTR (push)
Brisbane.
New, still in box.
Just bought this, and it is not required.
Here's where it sits in the scheme of things.
Stock
HD Range
Sports Range
Then you're at twin plates... (which it turns out my car already has, hence the sale.)
$550 + freight from the cheap places online.
$500 posted from me.
0411 870 150
  • 3 weeks later...
how much kw is it meant to be able to handle?
There's blokes selling these sort of things saying 350kw, but if I had that power it'd be twin plate time for sure. I was going to have a crack at 300kw with it, had 230kw at the wheels and they said it had miles of headroom at that power level. Torque ratings here - http://www.kudosmotorsports.com/catalog/pr...;products_id=27
  • 4 weeks later...
I just put one of these in My R33 GTST. I bought mine new and was told by whom i purchased it from (Kudos) the R32 GTR one is same as R33 GTST one. This might help you get a few more bites on selling it. Cheers. Any queries contact Andrew from Kudos he can confirm if needed.
Free BUMP.
+1 for these fitting straight into a R33 Gts-T. I as well bought this from Andrew from Kudos. He told me he has had many customers achieving over 270RWKW's with this clutch in R32 GTR's and said it could quite easily reach the 300rwkw mark on R33 Gts-T's. Good luck with the sale champ, Cheers :cheers:
Have one in my car. Awesome. Surprised it hasnt sold already. Hold steady you'll sell it. They are rated at around 260rwkw and are perfect for a 33Gtst
$450 guys! Cheap top of the range organic single brand new in the box.
Hi,
I'll call you or you can call Alex on 0433558872.450 freighted to Melb Vic. 3195 is ok by me.will send you deposit balance COD ??
cheers
Alex
Hi,
cheers
Alex
Hi, all
Rang 0411 870 150. it is a wrong number. it belongs to a real estate agent !!!????
plz verify
Alex
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
