  • Replies 118
Posted Images
FYI People
Just heard that channel 7 is at an accident scene ATM gathering footage of a red R33 that has taken out a stobie pole on Port Rd.
We're going to be completely F#*Ked if this doesn't stop for at least 6 months.
EDIT!!
Apparently it was a 32 not a 33
Edited by D_Stirls
FYI People
not watching the new atm, is it severe? or just injuries?
hope its not a speeding incident :P
ted180, I was prepared to overlook the fact that you were posting a banned members thoughts in a post.....up until the cheap shot.
So as Andrew said earlier about monitoring IP's, posting thru another member is no different......banned means banned!
You have therefore scored yourself a warning and you can thank Nisskid for that........for anyone else wishing to post banned members posts.....don't do it, otherwise what's the point of even giving someone time out?!
FYI People
Hope they are okay and like Unit Zero said hope it wasnt a speeding incident.
A Skyline aint the only car which can take out a stobie though......
Edited by 93GTST
That's not the point though because you can bet your ass that isn't what the news will be saying tonight.
Yeah thats right, what you just said is what I meant. Maybe I should have used a different choice of words :P
EDIT -
Your post was fine up until that line.
I honestly don't see what was wrong with that, it was a genuine disclaimer, last time he posted about defects it was misinterpreted as a personal attack on sled, to remove any doubt he made sure it was known it had no subliminal value. It was either post it as is and risk another misinterpretation, extending the ban, or making it clear it wasn't a personal attack, seemed like the responsible thing to do.
Ultimately, you can't really expect to ban a member for a 100% innocent post that you misinterpreted, and not expect to leave a bitter taste in their mouth.
Well I'm not getting into the nitty gritty of your beef, however for some reason you (nisskid) were banned - now if you don't like that, you can always appeal to the other mods of the board, I'm sure they will hear you out and decide for themselves if sled was being out of line. Or, sometimes its easier to just cop the holiday and let things pass naturally. It would have been a 100% innocent post but you mentioned his name - I take this as a baiting... there just simply wasn't any need for it.
And ted, you probably should have known better than to post for a temporarily banned member... but it seems like you only ever post negative comments these days so I doubt my words would mean anything to you at this stage.
-D
I don't give a rats about the content......DONT POST ON BEHALF OF BANNED MEMBERS!!
So what cheap shot were you referring to then?
-D
The 100% innocent comment that he was banned for never mentioned his name, it had nothing to do with SLED. This is the post that he was banned for:
http://www.skylinesaustralia.com/forums/in...t&p=4511506
He was banned on the grounds that Sled thought the post was subliminally directed at him as a mod.
You be the judge.
You be the judge.
Actually he was banned for the posts leading up to post #57 (on page 3) as well I suspect some PM arguments that were previously alluded to.. it just so happens that sled didnt respond to it until you'd already posted again, an estimated duration of 6 hours difference. like I said, I'm not going to get into whether or not either one of you are right, simply because I just don't care. However if you have an axe to grind against any single mod, speak to the rest of the mods and make an official complaint. Fighting in public is undignified.
-D
and there we go the opening story on Channel 7, i only saw the last 15 seconds though but they were questioning the power and availability of the performance import vehicles dues to their low cost. They claimed than Vinh's WRX only cost $11,000.
Well done Nene.. This looks like a step in the right direction :P
Tho Neils comments seem broad and normal but him making the contact is atleast nice..
Has Neil helped out on any cruises yet that SAU has organised?
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
    • There are guys on Facebook under, Infiniti Owners Australia   https://www.facebook.com/share/g/1Z3RbPqx4k/?mibextid=wwXIfr What Whp are you after and I can help, and join this Q group in the states. https://www.facebook.com/share/g/19A59cN3JR/?mibextid=wwXIfr
    • Does any of you guys have instagram pages for your builds? Keen to see some Aussie builds. I still can't figure out how to post photos in here.
    • That awesome thanks for that.
    • You can Remote any of these VR30..globally  Check: AMS Performance | Racebox | Sonic Tune | Soho | Z Motorsports | Specialty Z    Performance Parts | AMS | Z Motorsports | Boosted 6 |    Exhaust | Fast Intentions | ARK | MBRP Motordyne | Borla    There is someone in Sydney with 650whp   I am at 430whp without flex fuel, but FBO & Flex-fuel will push you to 500whp!!
