hi guys,
has anyone in here with a R34 non turbo chucked in a rb25det neo from a GTT into their car?
was it a direct plug in wire job?
im planning to just get the complete motor & ecu and whack it in (using the existing loom).
any tips? problems you came across etc?
cheers
https://www.sau.com.au/forums/topic/263606-neo-rb25det-into-a-na-r34/
Not that I've done the conversion but the wiring loom will be slightly different to cater for the sensors related to boost pressure. I know for one there is a boost pressure sensor mounted near the firewall that I doubt would be present on the non-turbo wiring loom. There are probably a few extra sensors that are present on the turbo loom as opposed to the non-turbo loom.
brakes, diff & wheels are sorted.
main concern is wiring in the hunka junk.
definatelly considering it nate, for $1500 for a neo det motor is less then half price & better in the long run.
only thing left to do after is det gearbox + tailshaft & im set.
if RB's are like any other nissan family engine swap (which ill be my left nut that they are) youll be fine using your old loom, maybe some things need minor mods, but they wouldnt be anything to go to town about, nissan would be crazy to make them very different (if at all)
yeah for the cost of a few wires you'd think they would make all the looms the same and just swap the ecu etc between NAs and Ts
My advice is not to use the standard ECU, it gets upset when it looks for the TCS/ABS controller, HICAS ECU, Boost sensor and a myriad of other minor ECU's scattered through the R34. A power FC or some other standalone would make it a lot easier to do as you won't have to trick as many inputs (as they don't use them)
As for the main sensors on the engine they're plug 'n' play from one engine to the other so you won't have to touch the loom at all :) Oh and take the butterfly valve out of the TCS throttle....2 scews hold the brass disc, easy to remove.
  dori34 said:
all good fellas,
thanks for the reply dan but i sticking with the NA+T
coming soon, keep an eye out for my build up thread :stupid:
Looking forward to seeing this :D Particularly with you using the Nistune, assuming that's what you're still going ahead with.
Im planning this aswell, except gonna be a bit more difficult for me as there are complications... anyway I got a gt-v, the turbo model r34 without the actual turbo, it has the brakes, diff etc but what about the gearbox? anyone know?
  666DAN said:
Didn't think you could use the Nistune on the N/A ECU...it's a pretty basic shitty thing with no upgrade ports on the board :S
hm good point, i told my tuner that im doing a na+t he said its suitable so maybe it is?
i dont want to keep hassling him with questions until its its done end of may so we'll see in 5-6 weeks :P
Who's tuning it?
i dont want to keep hassling him with questions until its its done end of may so we'll see in 5-6 weeks :)
May be a nice little surprise when they crack it open and see it's an R33 N/A type board :)
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
