i was taking the head bolts on my engine and stripped one, tryed another one that came out, tryed another that stripped again, tryed another and that work. how do i get stripped bolts out, and these bolts were done up really tight something like 50nm of torque so not hard to get out, would tapping be the best option? grind the head off? or am i buggered and need a hole new engine cos of this? the head is cracked so damaging the head taking these bolts out doesn't bother me.
https://www.sau.com.au/forums/topic/263636-stripped-bolt/
You rounded off the head of the bolts or stripped the thread?
Rounded off bolts I use the next size down in the nearest imperial socket, usually can knock it on the remains and undo the bolt. Only use sockets you won't worry about breaking or otherwise ruining.
Best prevention is to use good quality tools with the correct size socket.
https://www.sau.com.au/forums/topic/263636-stripped-bolt/#findComment-4510464
if u want to spend money go to bunnings and buy a set of irwin bolt extractors they r basically a socket with teeth that bite into the stripped bolt head....they r about 50 bucks a set but they will get 90% of stripped bolts out.
Edited by ficko
https://www.sau.com.au/forums/topic/263636-stripped-bolt/#findComment-4510542
Another method is to use "Ezy-Outs". Ezy-Outs are a tapered tap with a reverse thread.
You drill a hole into the sheared bot, then insert the Ezy-Out, and as you turn it anticlockwise, it bites in to the bolt, and screws it out.
They are designed for exactly this circumstance (stripped heads off bolts). You can buy cheap sets, though name brands from Tool Shops do the trick.
Good luck Cobber............... Easy to get broken bolts out with these gadgets.
https://www.sau.com.au/forums/topic/263636-stripped-bolt/#findComment-4510566
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
