i was taking the head bolts on my engine and stripped one, tryed another one that came out, tryed another that stripped again, tryed another and that work. how do i get stripped bolts out, and these bolts were done up really tight something like 50nm of torque so not hard to get out, would tapping be the best option? grind the head off? or am i buggered and need a hole new engine cos of this? the head is cracked so damaging the head taking these bolts out doesn't bother me.
https://www.sau.com.au/forums/topic/263636-stripped-bolt/
You rounded off the head of the bolts or stripped the thread?
Rounded off bolts I use the next size down in the nearest imperial socket, usually can knock it on the remains and undo the bolt. Only use sockets you won't worry about breaking or otherwise ruining.
Best prevention is to use good quality tools with the correct size socket.
https://www.sau.com.au/forums/topic/263636-stripped-bolt/#findComment-4510464
if u want to spend money go to bunnings and buy a set of irwin bolt extractors they r basically a socket with teeth that bite into the stripped bolt head....they r about 50 bucks a set but they will get 90% of stripped bolts out.
Edited by ficko
https://www.sau.com.au/forums/topic/263636-stripped-bolt/#findComment-4510542
Another method is to use "Ezy-Outs". Ezy-Outs are a tapered tap with a reverse thread.
You drill a hole into the sheared bot, then insert the Ezy-Out, and as you turn it anticlockwise, it bites in to the bolt, and screws it out.
They are designed for exactly this circumstance (stripped heads off bolts). You can buy cheap sets, though name brands from Tool Shops do the trick.
Good luck Cobber............... Easy to get broken bolts out with these gadgets.
https://www.sau.com.au/forums/topic/263636-stripped-bolt/#findComment-4510566
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
    • this is the reason we have more than one child right?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
