Make: Nissan
Model: 89' r31 S3 Executive
Colour: White
Engine: RB25DET
Trans: RB25 5spd manual
Mods:
*rb25det engine + gearbox.
*boss built 28spline mini spool (4.11 ratio)
*S13 HSD hr fully adjustable coilovers all round
*r33 lower control arms
*r33 front brakes
*S14 5 stud front hubs
*KKR 480 turbo
*40mm external gate (14psi spring) an screamer
*turbosmart V-port BOV
*custom turbo back 3" exhaust with x-force muffler
*custom made stainless bolt on plenum (garage7)
*custom stainless high mount mani
*set of gauges, inc: water temp, boost, oil temp, oil pressure
*tight racing bucket seats
*custom tailshaft (hardie spicer)
*bolt on 35mm 4-5 stud adapters on rear
*sports/drift wheel
*17*9 black driftex
*17*9 an 17*8 3 spoke wheels
*battery converted 2 in boot
*electronic dual stage boost controller
*rb20det tunable ecu
*complete street trim
Car is defected 4 too low an uncomplied/uncertified engine mods...
This is the straightest r31 u will ever c...was owned by my grandparents from new.
No crash history and all 100% original paint/panel.
Swaps will b considered
Can PM/reply on post or msg, 0447459701
More pics upon request
Westy
Hey man, whats your price. I'm interested but I don't want to waste your time and mine trying to figure out how much you want.
as said really keen 4 a swap 4 a neat 32 or lookin round 14,000 ono.
will drop lower but car will loose parts..
more parts 2 add wen i get round 2 it..eg:SARD fuel pressure reg, gts2 kit, 6 puk ceramic x-treme drift clutch ect...
ur a joke mate not ur posts
Correct, but good to see you finally follow Forum regulations and post up a price.
If you had posted a price to begin with, my post wouldn't have happened :cheers:
you will not get 14 for it the market is shite but i dont think you would have got that even if it werent defected just run it over the pits and then try selling it
i dont expect 14k.
its a startin point...
give me genuine offers an ill either accept it or i wont...
i dont give a rats arse if u dont think i can get wat i want 4 it...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
