BRAND NEW IN BOX
UNIDEN
GPS NAVIGATION SYSTEM
MODEL- TRAX430
$350 ONO open to offers
The New Uniden TRAX 430 combines the latest in GPS technology and software. Designed by Uniden’s experienced team of engineers. Imagine driving from A to B in 360°, well that is a reality of this innovative feature of the Uniden TRAX 430 allowing you to view Famous Landmark in 3D such as the Sydney Opera House, Queen Victoria Building and Centre Point Tower. View the landmark from any angle or fly around it in 360°. Like never before on a portable GPS navigation system while driving along a road it is now possible to see road elevations and land contours including road overpasses and bridges on the Uniden TRAX series.
Designed and engineered exclusively by Uniden, the TRAX Series include Text to Speech with Spoken Street Names, which enhances audible directions and makes finding a location even simpler. With an early warning system with built in nationwide coverage of fixed speed and red-light cameras and an over speed alert makes the TRAX 430 a great safety tool to have as your companion in the car.
The screen is super bright, removing glare for crystal clear viewing. It also switches automatically to night mode for easy, glare-free viewing after dark. For drivers who travel to more than one location in a day, multipoint route planning allows for multiple destinations to be programmed in advance. This allows drivers to go from one map to the next, taking the fastest and most direct route. Predictive keyboard text also reduces the destination search time and if drivers make a wrong turn in a pre-programmed destination, the system will recalculate directions immediately.
When it comes to portable GPS car navigation systems the Uniden TRAX series is in a class of its own. It makes your trips safer and faster while giving you peace of mind that you will reach your destination on time, every time.
FEATURES
High Definition 4.3" Non-Reflective LCD Display for Crystal Clear Viewing
360° 3D Landmarks
3D Terrain
Spoken Street Names (TTS)
Multi Destination / Route Planning
Simple Mode / Advanced Mode
Touch Screen
Lane Indicator
Easy Plug & Go
Multi Languages
Up to 600,000 Points of Interest
Red Light Camera
Fixed Speed Camera
Over Speed Alert
Predictive Keyboard
Auto Route Recalculation
Turn by Turn Instructions
Global Mapping Available
Automatic day & night switching modes
Additional Features:
Pixels: 272" X 480"
Battery Life: 3 Hours
Operating System: Win CE 5.0 Core
GPS Receiver Type: Nemerix
Processor Speed: 400MHz
Dimensions: 128mm (W) X 79mm (H) X 23mm (D)
Weight: 214g
https://www.sau.com.au/forums/topic/263638-uniden-trax430/
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
