hey i had 2 broken studs on my exhaust manifold (broken off rigt in, no stud sticking out to grab onto). I managed to remove one of them but while i was drilling a small hole in the center of the second one te drill bit snapped and there is no possible way to get the broken bit out so that means i carnt drill into the stud to remove it . So does anyone have any ideas how to get it out ?
its not seized in there cos before the bit broke off i could unscrew it a few turns before it gets tight but i couldnt get a good enough grip on it to unscrew it out completely. I know that a mig could tack enough metal so that i could undo it but i onl have an arc here and that would just stuff it up. I dont wana have to remove the head so i can take it somewhere to get done so i was wondering what ideas do you guys have ?
https://www.sau.com.au/forums/topic/26364-stud-removal/
hi, i had some exhaust studs snap off like yours, but was a bit luckier with the drill. While extracting one of mine i ended up drilling way off centre, but still manged to get it out. can you drill another hole off centre, you say the stud was loose. Just use a nut or similar as a guide(and vise grips to hold nut) to keep from drilling into head. From memory I used an extractor of about 3.5mm dia, i cant remember the brand (but not one with a thread, just parallel ribs running the length of it, someone mentioned the brand on another post), an excellent product!. Other than that i can only think your solution is best.
P.S. I replaced all the studs at the same time, another couple of them decided to break during that process, which was in one way lucky cause its not a job you want to do twice!
https://www.sau.com.au/forums/topic/26364-stud-removal/#findComment-560732
thanks, i ended up getting it out by ligtly hammering a flathead screwdriver into the hole ..
Another question is should i use anything on the new studs?
one guy told me i need locktite, another guy told me to use an anti seize on the studs before putting them in ... so which is it?
from the looks of the old studs there is nothing used on te threads..
Also does anyone know the correct torque for putting the studs in ?
https://www.sau.com.au/forums/topic/26364-stud-removal/#findComment-560766
yea it is fairly common . very easy to get it out as long as u can get to it the ones near the front are easy to get to on the car , dont know about the last one or 2 though .
i use an easyout to get them out , 1 k $ thats very expensive if u dont have to have the cil head out . the studs are about 2-3 $ each from nissan
https://www.sau.com.au/forums/topic/26364-stud-removal/#findComment-571668
I removed the turbo and exhaust manifold to get to mine ..
See if you can find a place that has reverse drill bits and make sure its a cobolt tipped one (i think thats what they are called) cos otherwise you blunten alot of normal drill bits trying to drill a hole in the studs ..
Hey by the way im one of the most lazyest bitches cos i still havent put the car back togeter yet .. i was thinking of getting the manifold sandblasted while its off so i can paint it .. anyone know its its ok to sandblast it inside and out ?
and will the sandblasting afect the manifold flanges ie will i have to get it machined if sandblasted?
https://www.sau.com.au/forums/topic/26364-stud-removal/#findComment-576527
I have 2 studs broken on my RB20, and i got some quotes yesterday. One was for 650 from APC and the other was 600 from Gavin Wood. I am thinking of going thru Gavin becuase he has done em before and he will replace all 12 studs. Do u think the price is a bit high? I know that the studs are only a few dorrars from Nissan. He also said that the manifold might need some machining if the face of the flanges are a bit bowed.
https://www.sau.com.au/forums/topic/26364-stud-removal/#findComment-579452
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
