You ask an interesting question there.
You can either have it curve up over the radiator and square off over the cam covers or cross over underneath and have two pipes go back over.
The "over" way makes general head maintenance even worse but it makes upg. to a front plenum easy.
The "under" way makes a front plenum hard.
T.
My intake piping near the throttle body/engine/radiator was a shitload hotter in the factory location, when compared to the new piping in the front-facing location which doesn't really go near any of those aforementioned things.
I've been told by a few people that the air moves too quickly for heat soak to be an issue, but i dunno, the old piping method is so long that it has to have at least some measurable effect.
Edit: my old intercooler was still front mount, so the piping near the radiator (under) wasn't "factory" as such, but the rest of it was fairly stock standard.
The less clutter their is in an engine bay the better I say. I've got the piping going underneath and although the piping is alittle longer it leaves much more room for other things like oil coolers etc etc.
Not only thing but almost every engine bay i've seen with the 'behind the radiator' has had issues with bonnets or repairs or removing/replacing parts etc.
I dont think it would make a huge difference from a performance point of view, apart from pipework being a bit longer if you go with the stock location, but I had a couple of other considerations that I used in the choice, they were:
I was planning on swapping to a front facing plenum
I wanted the hole that is freed up in the front of the engine bay to be used for a CAI
For the size of cooler I wanted, it was difficult to find one with an end tank design suited to using the stock pipe locations.
Hi T0nyGTSt, there is 3rd way, by having a 120 degree bend at the throttle body. Saves about 800 mm of pipework and no need for it to run behind the radiator.
I'll dig up and post some pictures of the Gibson R31 and an R33 that had the same system.
I have had a fair bit to do with an RB25DET with the 120 degree setup. Made 251rwkw with stock injectors and internals. Happens to be a green Silvia in the latest issue of Zoom (No. 69...)
Seemed to work fairly well. The 120 degree bend did get condensation on cold nights with high boost so I assume there is a noticable pressure drop around this area.
IMHO...
Originally posted by T0nyGTSt
In the interests of further education, I present this pic:
http://www.nitroware.net/~tony/r32_120d.jpg
I must admit is it not too common as I've never seen one in the flesh so to speak.
T.
Probably because it's so fugly :D
Well do you want the benefits of shorter pipe work?
or
Do you want neat and tidy wank appeal ?
why does no one consider running the pipes in opposite directions if you want to keep the 'in between raditor/engine' tidy apporach? as in come out of turbo, behind raditor, thru intercooler, up thru stock postition, then into cross over pipe....
I already have them, and shorter than that. Sorry if your car is done like that and I offended you, I didn't mean to. It's just my opinion, and probably a lot of others or I'm sure we'd see more of it around. Ok it's not fugly, just seems a bit "untidy" to me. But each to my own, I'm not going to bag it out! I was kidding earlier. There are much fuglier engine bays than that one :D
yeah why dont more people run the piping the way Skyrine-Dave said?that way you at least have the intercoolled air exposed to the heat of the engine bay for the least amount of time,except if you have a front facing plenum.my sons r33 gtst is done this way & doesn't seem to have any probs.
cheers
warrick
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
