Alright, garage cleanout time, this is what is still for sale.
Misc:
- FD3S RX7 RS - R Standard springs and shocks (all four corners) - $300
S13 Silvia Parts / 180SX Type X parts:
- 6 alloy rims - $400
2 x Work 5 spokes 15x6.5, 4 x 114.3
4 x Mullins 5 spokes 15x6, 4 x 114.3
Tyres are reasonable, consider them drift rims.
- Silvia Taillights x 2 - $50
- Standard Side Mount Intercooler - $80
- Front Sway Bar + Link rods - $60
- Standard Tension Rods - $50 pair
- Super Hicas - working fine - $70
- Type X bonnet, silver, as new - $250
- Standard Diff Centre - $90
- Leather Type X air bag steering wheel - $250
- Whiteline quick release front strut bar - $150
- VARIS Carbon Fibre rear diffuser - $500
(pictures below, the actual diffuser fitted to a friends old car)
R33 GTR Vspec parts for sale:
- std front GTR sway bar - $50
no link rods
- std computer - $200
- std centre guage cluster - $120
- std springs and shock assembly (all four corners) - $250
shocks have been rebuilt, very good condition
- aftermarket front pipe for twin turbo setup - $150
Small Damaged Area on Front pipe:
Parts are located in Sydney, pickup only!
PM me for contact details!
https://www.sau.com.au/forums/topic/263661-r33gtr-s13-fd3s/
  • 1 month later...
Bringing this back up,
Note would trade parts (& cash where needed) for other parts of interest that I need;
- R33 GTST brakes + S13 5 stud conversion gear (either aftermaket hubs or S14 gear)
May also consider S15 / Z32 front Callipers
- Set of Work Emotion XD9's (Gunmetal preferred) in
2 rims x 17 X 8.5, 5-114.3 / +25
2 rims x 17 X 9.5, 5-114.3 / +17, or +28
- Rays Lugnuts, 25 x 1.25mm type
- Takata 4 point, 3" harness
- SR20, 740cc Injectors
- SR20, Nistune or PowerFC ecu's
- Z32 afm
- Oil Cooler setup for SR
- Aftermarket radiator for SR (42mm or larger)
https://www.sau.com.au/forums/topic/263661-r33gtr-s13-fd3s/#findComment-4577163
Misc:
- FD3S RX7 RS-R Standard springs and shocks (all four corners) - $200
- 6 alloy rims - $300
4 x Mullins 5 spokes 15x6, 4 x 114.3 (2 spray painted black)
Tyres are reasonable (some good, some below average), consider them drift rims.
- S13 Silvia Taillights x 2 - $50
- S13 Standard Side Mount Intercooler - $80
- S13 Front Sway Bar + Link rods - $60
- S13 Standard Tension Rods - $50 pair
- S13 Super Hicas - working fine - $70
- S13 Standard Diff Centre - $90
- RPS13 Leather Type X air bag steering wheel - $250
- S13 Whiteline quick release front strut bar - $150
- VARIS Carbon Fibre rear diffuser - $450
no link rods
- std computer - $150
- std centre guage cluster - $100
- std springs and shock assembly (all four corners) - $200
- aftermarket front pipe for twin turbo setup - $80
Price drops, moving in a few weeks, need this stuff gone!
Note would trade parts (& cash where needed) for other parts of interest that I still need;
- Bolt in cage for 180SX
- R33 GTR Passenger seat
- R33 GTR Brembo's (Callipers Only, no pads or rotors)
Also, seeing if I can pre-sell these rims, they will be off the car and available in approximately 3 - 4 weeks at this stage.
Lightweight BBS Rims, 4 x 114.3, all in good condition with BBS center caps and BBS valve covers. One rim has small gutter rash.
Fronts are 17 x 7
Rears are 17 x 8
(offsets coming later tonight)
Tyres fitted at the moment are Falken Azenzis (615s), approximately 3 weeks old, 90% tread remaining. (One tyre has tiny flatspot - slight noisy up to about 55km/h, only going to be noticeable if you run lots of camber).
Asking $2000
https://www.sau.com.au/forums/topic/263661-r33gtr-s13-fd3s/#findComment-4589340
  • 3 weeks later...
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
