hey guys i recently put in a manual boost controller in my rb20 32, and looking at my boost tacho boosting to 12psi is good, happy with response etc, but as i turn up the boost to say 14-16psi the car feels like it doesnt move and has trouble boosting, no G force whatso eva.....
btw. its got turbo back 3" exhaust, FMIC, pod filter, using motul 4100 oil and standard ngk plugs
any ideas?
https://www.sau.com.au/forums/topic/263693-manual-boost-controllers/
Factory boost cut/fuel cut. I put a turbotech in after Christmas and same thing happened, at 12psi wouldn't rev all the way to redline. I went down to Mercury Motorsport, they said it was easy as to tune out, so I am going to get an ecu remap with them once I have put my intercooler in.
Til then I have just wound the boost down and staying away from redline as you can't be sure the air fuel mix is safe anyway. I'm not 100% sure on what actually causes it - You may be able to just get a fuel cut defender, but its probably worth getting a tune. My view is that unless my car is tuned to make use of all the mods I have done, I've just wasted money on buying them.
Regardless, I wouldnt recommend running over 12psi on stock turbo, unless you're happy to have it die. In that case maybe it isnt worth tuning til you blow it and upgrade to a high-flow or aftermarket.
