R33 Auto - Manual Conversation - Speedo
Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things. -
I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
@Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
It's certainly not the first choice, but it is a perfectly good bandaid when the alternative is to anger f**k the thing with a blowtorch. It's not just noise. It f**ks bearings.
