  • Replies 505
Posted Images
iirc , npo's fall under org.au , com.au requires an abn
another idea with what Damo said
love this and damo's first one they are great please print them off and bring to the meeting please :)
Also thanks sled xx
Thanx to all so far that are really keen to help me i intend to get this up running and working cant wait for next wednesday
Also thanks sled xx
if my idea goes according to plan ill be there with some high res versions for people to see ;)
thats some really good work there Mitch
i am with ruby on the sticker he likes lol...red blue and white
the boys in blue will be able to identify us properly :)
The one mitch posted just looks so damn hot tho
its good to have white separating the colors as red and blue are primary opposite colors
like the aussie american and french flags heh
-D
might not be a need to get www and domain hosting if christian allows us to have sa.skylinesaustralia.com as a CNAME with a subforum;)
-D
what about RUNVS?
what about it?
I like the first one. What would it look like if you replaced the "." (dot) with a "/" (forward slash) ?
That's obvious with his singling out Cara's plate.
Nothing wrong with RUNVS 2 ... Cara paid mtoro reg for it, she's entitled to whatever plate she wants.
What about UNVME 2?
Still complaining?
yes ruby, i do nvu :)
not til next january.
cant wait, mums making a cake shaped like skyline with runvs plates.
oh thanks so much ted, but my birthday isnt until june. but thankyou for your lovely consideration.
Now that I've seen both final options, I like either of them ... / or no /
I do like the idea of the blue SA at the end, sorta makes no need for the / now
Red white and blue. I reckon we stick with those Nissan colours :)
We're gunna have the coolest logo out! ;) Well done lads.
Bloody oath Bruce!
-D
i take one evening off to swear at the corolla and something awesome like this happens!!!
im definitely in, happy to help however i can :)
will do my best to be at villis on wed nite too (provided the rolla is going)
top idea kellie.
Guest
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
