Efi Performance Dyno Day + Cruise
Sammy34
 Share
ifs it someone from here who has driven a line before yes
if it was some random boostcruiser or something Hell NO
Haha boostcruise has such a reputation, a well deserved one at that mind
  • Replies 130
english ppl have a reputation too joe - but u dont see me dogging you :P
hopefully my car is sweet for sat :P
when u guys say late.. is that late arvo or late as in late night?
hopefully my car is sweet for sat :D
Haha thats because its not a negative reputation :P
Seeing as it starts at 9:30PM id say late nite tristan
Haha thats because its not a negative reputation :)
ur lucky im not going to judge u too cronicly cuz i wana steal your wheels - but it says 930AM you pom!
fail.
fail.
ummmm.......yea, yea thats what i said.......9AM.... :)
Haha
Attending:
- Sammy34 + Dyno
- Turbotonic + Dyno
- TIR60 + Dyno
- Slow S13
- rb25kateosaurus/Dale
- PWND + Dyno
- E-Z + Dyno
- 45ULT
- wannaslide
- craigy32 + Dyno
- Brandon + Dyno
- NOJ37
- GimpS-R34
Gonna have to take the Dyno off me. I dont really know how to make it to 2wd... I'll be dropping by around 10 to say Hi though. Cheers!
Awesome! been looking forward to this for AGES! Is there still a limit of 20 people for dyno runs sammy?
mate, I havent spoken with whitey regarding that in a while. So im not sure, He will let everyone know whats going on when we get there.
Fair enough, Shotgun for a dyno spot if there are any left then :O
Was a great day, nice cars there, most of you wernt there but Varun from 101 motor cafe, his black R32 GTR made 824hp with 100 shot of gas.
great day, thnx to all who did make it. Hopefully we get more sau down there next time around. Some unreal cars showed up, see if we can get some photos up whitey.
thanks to Troy and Whitey for putting on an awesome day had a great turn out. everything went smooth saw some good numbers unfortunately had a couple of hick ups with 'FAT GTR' and didn't quite get the power he wanted but still a great day hopefully another one will be organised again soon and try to get some more cars on the rollers.
Cheers to all,
Smitho
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
