hey i was hookin my sub an amp up today an yesterday(stupid idea) and i had it all working and then when i tried to start my car it made some weeeird noises and think i blew ignition fuse i checked it looked pretty toast what do i do?
think its somethin to do with my ground cable,
this is in an r33 btw
cheers heaps
https://www.sau.com.au/forums/topic/263824-need-help-asap/
cheers heaps
weird noises ? a bit vague can you describe it better then that, did it turn over? or just click?
sounds like a loose or bad connection on the battery. or corrosion , your not passing enough current to turn the engine over if it clicks or doesnt nothing but dash lights still work?
when you blow the fusible link , nothing works for the most part, does anything work in the car?
hope you hooked the amp direct to battery with a fuse, not use a existing wire from inside the car harness?
if you really blew the link/fuse you could have reversed the wires on battery or shorted out the main harness.
and one other thing is running a amp off existing wires will fry the fuse, its not designed to handle amp loads thru it?
Edited by sapphiregraphics
https://www.sau.com.au/forums/topic/263824-need-help-asap/#findComment-4514154
cheerz 4 the reply i got it goin mmy god it goes so good, skylines sound so good with sick audio an cant even hear outside soooooooooo good:D
https://www.sau.com.au/forums/topic/263824-need-help-asap/#findComment-4518337
